| Becker Type Rudders Has anybody experimented with a hinged flap rudder similar to the Becker/Hatlapa Design often used on ships ? It seems to me that their ability to provide lateral thrust and therefore assist with berthing would have benefits in harbours and rivers. Does anybody produce a rudder of this type at a reasonable price - I believe that the Becker product only starts at ship size ! |
| this has been done on 12-meter (former AC class) yachts as well, with some solutions dividing the rudder in more than two sections. Theoretically, by introducing camber to the rudder section this way, you'd need less of a rudder angle to get a required lift, so this might reduce resistance. A mechanical nightmare though, especially so in marine environments... bye Hans |
| Becker Rudder System Dear NB I am the master on the 62mts yacht Solemar. We utilise the Becker independent system and i have to say it is the best steering control I have ever used. I manouvre the vessel with rudders towed in 30dgs. That way I don't have to touch the steering agin until docking is complete. It is very positive steering with both normal and high speed pump backup. the vessel turns in it's own length with both engines ahead and rudders to full lock, either port or stbd. If I built a new vessel there would be no hesitation about installing this system again. Rgds Maxx.... |
| Van Der Velden manufactures high-lift "Barke" rudders for the yachting industry. I have been involved on a 150' Trideck built in the US, where these rudders were installed in an FRP hull. The resulting turning characteristics were impressive on sea trials, but I've not had the oppertunity to follow-up with the Captain regarding his overall opinion of the system. Van Der Velden provided the entire hydraulic system, and the vessel was ABS A1 Maltese Cross certified, so from the design side of the project, it was only a matter of figuring out the mounting details. I'll be most interested in future maintenence and servuce issues, as they compare with conventional rudders-we'll see. |
| boat size flap rudders Have a look at http://www.rudderpower.com/products.html. That's probably what you are looking for. It is a fact that a flap rudder can give you more lift (steering power) for less drag (resistance). It's added complexity though (and cost)... Cheers, Bruno Naval Architect Innomare |
| Becker type rudders This type of rudder for smaller boats with Provisional Patent style text and diagram. A two piece rudder,with D being a balanced rudder with an un-fixed shaft being supported inside A, D having a hinged tail-piece attached at C. A being a sleve supported by bearings with an attachment to turn tail-piece C when sleve A is turned at point E.
__________________ tomkane |
| 16' "sidewinder" type molds for sale | Mauserhaus | Boat Molds | 5 | 04-08-2009 06:20 PM |
| rudder's joessel formula | fede | Boat Design | 4 | 12-19-2005 01:19 AM |
| Rudders - What spec's are needed to build a rudder for an inboard? | AlaskaFisherman | Powerboats | 0 | 10-08-2005 08:48 PM |
| Need Help Finding Ducky Type Dinghy Plans | Scuba1 | Powerboats | 0 | 02-20-2005 09:17 PM |
| Need Help Finding Ducky Type Dinghy Plans | Scuba1 | Boat Design | 0 | 02-20-2005 09:15 PM |
