Old 03-21-2009, 02:40 AM
uys uys is offline
Rep: 10 Posts: 5
Bearing Strength of Composites
Hi there
I am trying to understand the mechanics of composites.I have down loaded Eric Greene's book,and found it very use full.I have a good understanding of mechanics,but some of the stuff is a bit over my head though.
a) Is the bearing strength of a laminate = to the compression strength of the material (as per data sheet) when eg. working out chain plate hole sizes?
b) Can I asume that eg. when a composite sole (400 EDB;H80;400 EDB) is tabed onto a hull with 50 mm of tabbing on the floor,and 50 mm tabbing onto the hull,that it is the shear strength properties of the resin system (data sheets) x 50 mm x (X) meter length of tabbing = strength in MPa that supports the floor?
It would be great if someone can point me in the right direction.
uys
cutlass bearing first or last? pasty63 Inboards 1 02-13-2009 05:15 PM
Composites Manie B Fiberglass and Composite Boat Building 3 12-10-2008 12:32 AM
Anyone familiar with US Composites? Sean B. Materials 2 07-24-2006 02:41 PM
Composites fencer Boat Design 10 07-08-2005 08:31 AM
Project on Composites Materials 2 03-11-2003 12:18 PM
