| Beam vs. Ride I have a quick question. In all of my boating years, I have always found that the wider the beam of a boat (sportfishermen), the better it rode (ie. pounded less) better than an equally LOA baot with a narrower beam. has anyone else experienced this? and is there a mathmatical or physical property that supports this? Blue heron |
| In my 67 years I have found just the opposite. How can a designer ever build us ( you and I ) the perfect boat? |
| Best ride in rough water is still a nuke submarine. Storms, dive a little. I know, no excitement left. |
| someone's ignoring the subtleties of the hull-shape, particularly the bow-sections, Also. Intrepid is correct, weight will have a bearing on the subject. Cheers, Tim B.
| I'm with Tim on the hull-shape subtleties thing. To get adequate lift to plane well, narrow hulls tend to need flatter slammier sections, while soft-landing deep deadrise hulls benefit from beam. |
| The wider boats that "Blue Heron" experienced may have been much heavier than the narrower ones. A heavy boat has a softer ride than a light one. |
| Dive alot, storms are not just on the surface of the ocean. Bill H. |
| In my 55 years of life and in geeneral everyday/ all kinds of use boating - I will say wider is always better if you have the turning room. |
| Florida Sharpie Length to beam ratio | Florida_mariner | Wooden Boat Building and Restoration | 6 | 04-19-2005 07:47 PM |
| Beam to length ratio? | Danielsan | Boat Design | 28 | 03-05-2005 01:14 PM |
| Overal beam of Tris vs Cats | patrik111 | Sailboats | 7 | 01-10-2005 11:13 AM |
| Hull Waterline Length to Beam | longngone | Boat Design | 12 | 10-22-2004 12:37 PM |
| Overall beam of Tris vs Cats | patrik111 | Boat Design | 2 | 09-28-2003 01:05 PM |
