Old 08-23-2008, 02:45 PM
wudenbote wudenbote is offline
Rep: 10 Posts: 31
Beam and depth increase
Fellow wooden boat lovers: Thanks for all the input I have received...it is much appreciated. I will continue to bug all of you until my project is completed. The boat I am going to build is a modified Pacific dory with an OAL of 20' 8". My question is this...I would like to increase the beam and depth by 20%. Am I correct in assuming that stability would not be an issue if I increase both the beam and depth and thickness of the frames by 20%? Using a percent figure should keep all relationships the same. The boat will be conventional marine ply over hardwood frames. At present I am building the strongback. Thanks for all the help.....and I ALWAYS finish my beer :-)
Old 08-24-2008, 12:12 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,397
Sounds like a really bad idea - basically, you are suggesting increasing the depth by the same amount as the size of the frames, which means the inside diameter of the frames stays the same, and the frames extend another 20% out. That is both unnecessary and weight adding.
You cant just apply an abritrary percentage to a design. You have stability issues by raising the centre of gravity,, and you are not increasing the length of the boat by 20% ..... and it goe on and on.
Get another boat design with the interior room and beam that you need - but modifying a design in this manner is a really bad idea.
Old 08-24-2008, 03:57 AM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 485
rwatson,
I don't think you got it right? Wasn't it a 20 % growth in molding and siding of frame? Sounds reasonable.
Your judgement of stability issues is based on what?
Increasing of beam by 20% will make her metacentric height (stability) about 20% higher. For:
BM = I/D
and I will grow 1.2^3 times and D will grow about 1.2^2 times. There is still room for a 20% rise of gravity...
Here BM is hight from bouyancy to metacentric, I is second moment of water plane and D is displacement.
wudenboat, you knew the new design is then about 1.4 times heavier too? You should use 16% thicker plywood (yes, hard to find).
Only shared knowledge can grow.
Old 08-24-2008, 05:57 AM
rwatson's Avatar
Oh yeah - sounds good easy.
I roughed up a quick sketch of the result.
Doesnt look like too many problems to me.
Old 08-24-2008, 08:55 AM
terhohalme's Avatar
Rep: 478 Posts: 485
OK, now I know how the pacific dory looks like.
Catamaran beam vs trimaran beam seadog1970 Multihulls 11 08-19-2007 05:49 AM
replacing diesel with lead to increase stability francis k Sailboats 3 01-25-2007 12:55 AM
Increase efficiency of rotating shaft. Jigar111 Propulsion 2 11-14-2006 03:50 PM
Could a fan in front of a sail increase speed? RGClark Boat Design 3 07-21-2006 10:17 PM
rpms increase but boat wont go any faster sleepinducer01 Powerboats 2 05-06-2006 08:56 PM
