  #46
Old 11-01-2007, 04:45 PM
chandler chandler is offline
Rep: 16 Posts: 378
Interesting idea alan, I thought you were sanding the bungs off.
I guess the slight excess on the sanding discs would work, pretty small bungs though as the disk would stop you dead after about 1/4". Am I still missing something?
  #47
Old 11-02-2007, 04:59 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
I AM sanding the bungs right down. This takes about one second per 1/2" bung. I use 50 or 60 grit. When you get almost flush, you stop. Later you go over the whole surface with longboard or lighter grit. I angle the sander and watch the bung go down at the edge of the disc, stopping when I am grazing the surface.
  #48
Old 11-02-2007, 05:16 PM
Rep: 16 Posts: 378
I guess that it depends on the wood the bungs are made of. IMO the time it takes to sand down a bung with any type of sander would be better spent on a fine pull saw, a sharp chisel, a sander? I don't think so .
  #49
Old 11-02-2007, 05:23 PM
Rep: 16 Posts: 378
Alan,
You are going to put a 1/32nd" radius on anything? I could do that with a piece of sand paper, probably 100 grit. What exactly are you talking about???
  #50
Old 11-02-2007, 08:34 PM
alan white's Avatar
I've done it every way. Sanding by using a random orbit with 50 grit is fastest. Period. Not much of a basis for argument when one of us is speaking from experience and the other shaking his head in disbelief (but has't tried it!). Give it a try and then comment.
  #51
Old 11-02-2007, 08:40 PM
alan white's Avatar
Alan,
Could you be more specific in your question, including a quote of mine you're referring to?
  #52
Old 11-03-2007, 11:52 AM
Rep: 16 Posts: 378
Alan you do the work of scrolling up to your quote.
I find it hard to believe you can sand bungs with 60 grit without putting divets in the planking. I also wonder how people in here get anything done spending enough time to post 5 times a day.
  #53
Old 11-03-2007, 12:16 PM
alan white's Avatar
See ya, Chandler.
Bead and cove technique / Bilodeau book sailsocal Fiberglass and Composite Boat Building 0 09-09-2006 01:46 AM
wiring on a 50' canoe cove wilezcoyote Electrical Systems 1 06-18-2006 09:15 AM
Apple for strips? Neverbehind Materials 11 06-12-2006 03:02 PM
Longer Cedar strips doesitfloat Wooden Boat Building and Restoration 4 02-21-2005 08:58 AM
bead and cove stripplanking trimix Boat Design 3 10-23-2004 12:01 AM
