Old 10-20-2004, 05:59 AM
trimix trimix is offline
Rep: 10 Posts: 35
bead and cove stripplanking
Is onyone can advice me about the choose of the radius knowing the width of the strips for bead and cove stripplanking ?
Is these another way to do which is more efficient, rapid and resin useless ?
Trim
Old 10-20-2004, 06:21 PM
Rep: 1397 Posts: 7,215
It is not critical. 19mm strips usuallly get a 25mm radius. It should be somewhat larger than the thickness.
Old 10-21-2004, 01:30 PM
SeaDrive SeaDrive is offline
Rep: 15 Posts: 223
The iconoclastic Tom MacNaughton has another view. He suggests using square strips without cove & bead. The 'v' between strips gets filled with epoxy, preventing glue starvation in the joint.
Old 10-23-2004, 01:01 AM
I usually plank with square edged strips on larger boats too. However, for very thin planking (5-6mm) , square edges don't work.
Useless glue and sanding stripplanking method trimix Boat Design 4 01-21-2005 12:57 PM
