| Bayfield 25 CE/CLR - Rig alternatives Just purches the last Bayfield 25 to be built in On. factory but problem is... No rigging. No mast (have boom), no sails, etc. Want to know: a) where to find specs/ plans for rigging b) Is it possibl;e to substitute a mast of same height? What do I need to look out for. (I have access to some used alum. spars) c)What strength/type of wire for shrouds, stays, etc. assuming sail area is max 240ft2? Thanks, Andre |
If you can't find the specs for your boat or get anyone out there to help you, there is a quick and dirty way to find out what you need to know. Go to your local boat yards and find boats similer to yours (Weight , Length, and Beam) and see what size mast and rigging they use. Try to find at least three boats to sample from. This will get you in the ballpark. Then go to Amazon.com and see if they have a book called RIGGER'S APPRENTICE. This book will tell you pretty much what's involved in settting up a sailboat rig. Though it is not a project to be taken lightly, with enough research and determination, it is definitly doable. Bob |
| Aftmast rigs??? | jdardozzi | Sailboats | 489 | 02-11-2012 07:22 AM |
| Sail Loading on Rig, Rig Loading on Vessel | brian eiland | Sailboats | 93 | 02-23-2011 08:19 PM |
| Why does a cutter rig point higher & sail faster? | Rich Kinard | Sailboats | 140 | 08-20-2008 07:43 PM |
| Alberg 29 rig on a Bayfield 25 | Sonie | Boat Design | 4 | 09-12-2005 06:31 PM |
| Masthead vs Fractional | Bradonvashon | Boat Design | 19 | 10-24-2003 12:39 PM |
