Old 07-25-2010, 12:30 PM
ChrisN67 ChrisN67 is offline
Rep: 47 Posts: 49
Battery Sizing and Location
I am running two diesels; 6LY2. I am using a VSR so I have dedicated cranking batteries. I chose the optima red top that had 1000 Cranking amps at 32C (I am in warm climate CCA really not an issue) Well the long and short is that the starting batteries are going to be mounted between outboard engine stringer and chine.
I wanted to place the House batteries in the same location to offset the 250lb genset on the other side of the boat. The engine bay is a totally sealed compartment with transom and forward blukhead.
Would you put all batteries in the engine bay or place them up front (as per initial boat layout)???
The boat now has surface drives so I want as much weight as possible in the stern.
Do most people place batteries in engine room? What if you had flooding..there goes the VHF etc..
Old 07-26-2010, 03:23 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,251
The batteries can be safely placed in the engine bay, where there is ample ventilation and room for heavy wiring. A somewhat elevated rack, say 1 ft above the bilge, will do fine. Against flooding you have of course two automatic bilge pumps, one of them could also be switched on manually.
Propellor sizing corglass Props 11 06-16-2010 03:10 PM
prop sizing trevone Outboards 6 12-01-2009 03:10 AM
Propeller sizing... Sean Herron Boat Design 1 10-27-2004 10:49 AM
Sizing a prop?... DrKirk Sailboats 14 10-06-2004 01:58 PM
Anchor Sizing CGWILSON Boat Design 2 06-21-2003 03:32 PM
