#676
In horspepower, your 36 Kw electric is comparible to +/- 120 Hp if I am right. That boat will move fast. Bert |
#677
| Hi PBW No objection if you discuss this concept with those 3 suppliers and see what they think about it. Whether they give the tumb up. a) modular in power size and voltage b) standard type "D" batteries or cylindrical batteries c) conductive paste between batteries if needed Attached 2 more photo's One showing the bottom with the inter connnections One showing the top with the rubber feet or rubber balls bert |
#678
douesn't sound either waterproof or super quick, but seems solid. |
#679
| I was more, - think "waterproof"? - and - "the Titanic did not sink" - - - so how about a robust workaround where the "water" in small occasional droplets, does not have significant immediate adverse impact, and the join mechanism is relatively straight forward and quick to effect (when putting on a trailer and going home)... and regularly wipe the exposed areas with 'petroleum jelly' (Vaseline?) Glad you found your tongue, and that it was not "the cat" as that would have been very painful and possibly give you some nasty disease...
__________________ Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story... A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy... |
#680
| bertku, how about filling the pipes with oil? thermal equalisation and conduction, no corrosion. seems right on, those chinese D or 3/2 D you found. For me the operating and storage lower temp limit is too high. I also note that the measured 1000 0.5C cycles reduced capacity to 70% not 80% as is more common. Also, lipo / lico chargers are not allowable (unlike with some other LiFePo, I heard) because they terminate at 4.2v and these cells at 3.65. |
#681
I know what you mean regarding water"proof". Some things actually ARE waterproof though. for instance, the bottles of soda. It is difficult for me to understand why waterproof to this standard, in a connexion, should be so infinitely hard to produce. And, if titanic had had enough empty soda bottles onboard, it never would have sunk! Anyhow, how would you make sure, in your connexion suggestion, that the battery poles did not meet each other? (bert, what is EMK?) |
#682
But I read that you ordered a sample, so you can soon determine its usefulness yourself; I fear the resistance will be disappointing. |
#683
| The oil filled cylinders to exclude water (corrosion) and for thermal dissipation is nice, but the stuff used in power-line transformers for that purpose, is VERY toxic and a thermal runaway explosion could cause more problems than any other option... Not on the list as far as I am concerned...
#684
| bad idea then... no other suitable fluid? But those little dehumidifier pellet bags, they put them with computers and such when shipping; that would be a good idea.. |
#685
http://pdf.directindustry.com/pdf/ma...407-13428.html |
#686
#687
| I must be missing something, here. Even if the grease IS conducting, what's to prevent it from causing a short circuit between cells. All grease I know of does not stay in the exact spot it is placed. You wind up with a big mess due to vibration, gravity, etc. Removing a cell to replace with be a slippery endeavor at the very least, as well. Porta Quote:
#688
| happy with that: http://www.2spi.com/catalog/vac/silv...-techdata.html this was the only exmaple i found in a hurry... having < 0.01 ohm per cm... |
#689
(Or is it hygroscopic? Anyway, it loves to absorb moisture...) Tom |
#690
| Masalai, by the time you are going to launch the boat, you can probably buy much better genset than the noisy IC you talked about. What about a Cyclone engine for instance? burns anything, and is more silent and compact, probably. They are not in mass production yet, far as I know, but will probably be by that time? I've a soft spot for thermoacoustic devices - should be even more cheap, compact, quieter and burn anything. I know, off topic, ssshhh. |
| Batteries in the bilge? | Squidly-Diddly | Boat Design | 5 | 10-25-2007 08:11 PM |
| Running Three Batteries... | JonM81 | Electrical Systems | 3 | 10-09-2006 06:57 PM |
| Custom Batteries ??? | bjl_sailor | Electrical Systems | 4 | 03-05-2005 05:39 PM |
| New Technologies? | Wynand N | Boat Design | 2 | 02-25-2005 02:56 PM |
| Shipbuilding Technologies 2001 | Scott | Education | 0 | 08-01-2001 12:40 PM |
