Old 03-30-2008, 03:18 PM
afrhydro's Avatar
afrhydro afrhydro is offline
Rep: 245 Posts: 243
well then copy some ones bottom dimensions and configuration and
go for it
the top cap can be any configuration you like
all we are saying is it is tricky not impossible
here's a bottom you can look at
its 20' by 8' i made this one just cut the dimensions down and your good to go
Bass Boat design, my first, will it work? suggestions...-picture-177.jpg  Bass Boat design, my first, will it work? suggestions...-picture-180.jpg
Old 03-30-2008, 04:11 PM
garrick garrick is offline
Rep: 10 Posts: 14
Thanks alot i'll use this, if you have any pictures and maybe even some pictures of construction or dimensions that would be cool too.
Old 03-30-2008, 05:23 PM
afrhydro's Avatar
Rep: 245 Posts: 243
ok then
its got a 6 " flat pad and a 10 degree dead rise and the first set of chines are 26" from outside to outside
the step is 10" deep and around 6" high the transom is 20" tall
if i was you i would stay around 6 1/2 to 7' foot wide minum and then go 16 or 17'
the pad and chines i would leave as i said
have fun
i would use okume ply wood or berch and clear fur for stringers
put the fuel tank in the back about 4' in front of the transom under the deck
good luck have fun
Some suggestions needed, 1 person mini speed boat design residentgearhed Boat Design 14 06-19-2011 03:05 PM
Opinion's on pinnacle of wooden bass boat design? Woolner's Ghost Boat Design 0 12-27-2006 12:17 PM
Building a boat based Higgins design or the LCVP and suggestions will be appreciated H-bomb Wooden Boat Building and Restoration 3 10-28-2006 05:28 PM
Bass boat design (any suggestions/info) justinDesign Boat Design 0 10-19-2006 12:22 AM
Suggestions for submitting boat design plans to industry/partners Marcum Marine Services & Employment 1 08-07-2001 11:55 PM
