Old 03-30-2010, 05:03 PM
shandog999 shandog999 is offline
Rep: 10 Posts: 3
(basic) Making a Boat Help!
Hey everyone,
Ok so last summer I belt a floating dock using styrofoam as a flotation device but its very shaky and just not very good quality so this summer I would like to build a boat that will last and is quality. My idea is to either build two canoes and put a deck on top, making it fairly large or to make a pontoon boat with the same idea. I also found that a rigid hulled inflatable boat is a very intriguing idea and I would be interested in giving that a shot if anybody knew how to make an inflatable boat, such as what materials to use and what exactly to do. I guess I'm asking if any had any ideas to kick start the discussion to see if there are any better ways to make this boat? Preferrably, I would like it to be cheap and lightweight, but I'm prepared to spend quite a bit of money to make this happen so initially any idea is perfect.
Thanks for your time,
shandog999
Old 03-30-2010, 05:04 PM
Rep: 10 Posts: 3
Also, I was wondering how to calculate buoyancy and what part of a boat's design makes it actually float? This is just for reference as I think it would be a great thing to know.
Thanks a lot,
shandog999
Old 03-30-2010, 05:46 PM
mizzenman mizzenman is offline
Rep: 10 Posts: 13
the boat will displace an amount of water that wheights as much as the boat. This is a natural law and can not be changed, it is called Archimedes Principle. The designer must se to it that the volume of the underwater body is as big as the wheight of the boat. if not the boat will simply setle on another level of flotation than what the designer intended.
volume calculations are made with Simpsons rule. Which is easy to understand mathematically, but kinda tedious to acctually use on a desing. Free!ship is a free designprogram that makes volume callculations.
If your out to save money id sugest you just buy a used pontoon boat.
Old 03-30-2010, 06:29 PM
Rep: 10 Posts: 3
@mizzenman
thanks for the info about a boat's general design but buying a used pontoon boat is a little out of my price range, how could you build the flotation devices that are used on a pontoon boat?
thanks
shandog999
Old 03-30-2010, 11:19 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Shandog
Probably the easiest and cheapest way to build a boat is to use the stitch-and-glue technique (plywood). The best way to make sure you're not wasting your time and effort in doing so would be to buy a set of stock plans. There are any number available, so you should be able to find what you are looking for. Give google a whirl....
For an introduction into hydrodynamics and boats in general, Dave Gerr's The Nature of Boats is a pretty good place to start.
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 03-31-2010, 05:52 AM
Rep: 10 Posts: 13
Originally Posted by shandog999 View Post
@mizzenman
thanks
shandog999
Designing and building your own boat is generaly not reagarded as a way to save money. It's mostly done by folks that like to build stuff and have the money to spend on it.
Also the advice from the Australian above is a good one. Buy plans from a good designer. That will prevent many mistakes and in the end save you money.
Maybe its different for pontoon boats.
How about the blue barrels that are used for mushel plantations? If you could get your hands on some of those and lock them in a rigid structure.
Old 03-31-2010, 05:38 PM
jim lee's Avatar
jim lee jim lee is offline
Rep: 217 Posts: 336
Here Shandog,
http://www.skagit.edu/cat_search3.asp?crs=676&cat=20082
This is taught on the Widby Island campus. (near seattle) Its cheap-ish and will go a long way in answering you're questions. I took this course and learned a lot!
-jim lee
J/35 No Tomorrows
Left Coast - Building a boat company from scratch.
Making a Boat mold??????? sportfishing Boatbuilding 41 05-18-2010 04:37 PM
Concept to basic line drawings - 40 foot power boat 67-LS1 Boat Design 47 12-03-2005 07:34 PM
Basic boat design tone50 Boat Design 3 09-04-2005 06:22 AM
pontoon boat parameters: basic sources? helipilot Boat Design 5 08-21-2005 10:29 AM
Basic reading for the starting boat-electrician Dutch Peter Electrical Systems 8 09-13-2004 09:50 PM
