| Barge Design - help needed I am interested in knowing at what size barge would one look at that suits the following criteria; 1. 500 ton load capacity - mainly for transporting grain/maize 2. also have space for four 12 meter containers in holds over and above load capacity 3. River (Congo) use and to be towed by tug 4. Possible current cost per ton displacement to build in USA$ I would be appreciated if someone can give me approximate LOA, beam and draft of such a vessel. Also looking for a NA that would like to be involved in designing such a barge - investment corporation want to build four of these units. Currently busy with feasibility studies and need numbers and cost.
| what kind of load, solid, liquid, grain, white goods, etc etc?? Craned on? I assume no Class certs etc required? What is max depth allowable...that will dictate the design somewhat, if the parts of the river it goes are shallow and/or silted up |
| Thanks Ad hoc Mainly used for harvested grain loaded through deck doors by conveyor belt (gravity). No class certification and max depth allowable not more than 7 meters loaded
| Sounds like a large floating 'skip' then really. How is the grain removed once onboard? |
| Slowly I'll bet. |
| Wynand I really depends upon many factors, since the beam and draft can be made to suit to actual loading and unloading, as well as some basic stability requirements. How the operation is to work, greatly influences the overall design. But i would say somewhere in the realm of 40m. But that depends on upon the length, is it too long for manoeuvrability in the river...how wide is the river...etc etc....so a bit more data on the river, and the operation is better to say with more certainty. |
| Small Barge Design Plans | nk09 | Boat Design | 8 | 03-13-2009 01:20 AM |
| Design of Concrete Pontoon/Barge | Robert Treseder | Boat Design | 1 | 11-19-2004 05:42 AM |
| Double hull barge design | fred Daly | Boat Design | 0 | 05-27-2004 12:46 PM |
| Barge Design | K Spears | Boat Design | 4 | 01-26-2004 11:39 PM |
| barge design | Boat Design | 0 | 02-09-2002 12:23 PM | |
