| Balanced Rudder Design Hi this is my first time on the site. I have a question about the design of balanced rudders in fast sailing craft. I'm building a 25 foot sailing skiff. My plan is to build twin balanced inboard rudders (Like an E-scow)so that at least the leeward rudder won't ventilate.(In fact the bearings are half way made and the profiles are cut out.) I'm using what might be termed a NACA 0013.5 section to accomodate the 0.875 inch ss rudder shaft. Are there thoughts / info on the best position to balance the rudder? Also the foil resulting shows a somewhat convex trailing edge. Does it help to straighten (flatten) this area? John |
| If you've used a 00 section, and it has a cusp, then it is the wrong shape The 00-series should not have a cusp.As far as balance goes, some folks go 20/80, and some swear that less is better (say 12/88). A lot depends on how much feel you want versus how little effort you want to out into steering. Steve |
| Thanks for your reply, Steve. I'm in the process of refining the leading edge to get the forward area between 12 and 20%. Also I'll check the section to make sure it is actually an 00 section. The program allows me to manipulate the distance aft to the max cord thickness. Perhaps I moved it to far aft. Is a 64 series superior to the 00? Anyway thanks again! John |
| Hi! Steve might tell you otherwise, but I would advice strongly against the 6X-series of foilsections as they are prone to leading edge separation and tend to stall at a lower angle of attack than the 00-series. As for the balance, I would make it about 14/86, but if you want to do it right, you should find the center of effort of the rudder and then check the distance to the centerline of the shaft. Larsson & Eliasson recommends a distance of 50 mm (regardless of rudder- and/or boatsize), but we've gone down to 40 mm on a number of our designs (and even 25 mm on one occasion), and they all behaved beautifully on all courses. Finding the center of effort is easy if you have a rectangular rudder - it's on the 25% chord line at a height that corresponds the geometric center. If the shape is not rectangular, the calculations become a bit more difficult - it will certainly take up too much space to explain it here, som I'm afraid you'll have to work that one out yourself! Good luck with your project! Søren Flening |
| Søren says: "Steve might tell you otherwise," Ummmmmm..... Pppppfffffttttttt ![]() I like the 00 series for rudders, but have used the 63-series with success. 'Nuff said. Steve |
| Okay-okay! You may just have been lucky, then... (I wanted to place a smiling smilie here, but I just get a "An error occurred"-message! Hope you get the message anyhow). |
| "Okay-okay! You may just have been lucky, then... " It's only luck when it goes wrong (bad luck, that is) - when it goes right it's called "good judgement". Or that's what they tell me. Got the message about the smilie. ![]() Steve |
| Yeah - that's what I mean! You were lucky to posess good judgment! |
| RE 00 series rudders Quote:
Thanks John |
| You might take a look at a symmetrical Eppler or Wortmann section. They are more modern than the NACA sections. Compared to the 4-digit sections they'd have more laminar flow, but not be as susceptible to leading edge separation as the NACA 6-series sections.
| Do anyone know where can i get the Eppler and Wortmann section data? Thanks in advance Daniel |
| Most complete collection of section coordinates I know: http://www.aae.uiuc.edu/m-selig/ads.html Less complete, but has some data in addition to coordinates: http://www.nasg.com/afdb/index-e.phtml
| naca 16 series I know naca 16 series to be best section for hydrofoil. While not for rudders? |
| naca 16 series Quote:
| College for Naval Architecture | Archive | Education | 15 | 04-07-2008 01:42 PM |
| Master in yacht design | ambas | Education | 26 | 05-11-2006 02:47 AM |
| Rudder Design and Broaching | joebobb | Boat Design | 0 | 02-25-2005 10:43 PM |
| Rudder design for solar boat | lost at sea | Boat Design | 9 | 01-26-2004 12:39 PM |
