Old 06-15-2008, 12:53 AM
BarryG BarryG is offline
BarryG
Rep: 10 Posts: 9
Balanced rudder design
Can anyone tell me what proportion of a balanced rudder is (typically) foreward of the rudder stock?
Old 06-15-2008, 02:19 AM
swanncat swanncat is offline
15% of total surface area. Brett
Old 06-15-2008, 04:21 AM
BarryG
Rep: 10 Posts: 9
Balanced Rudder
Thanks very much for the reply. As a result of posting the query the site immeditely threw up some previous discussions on the subject, which essentially confirm your reply.
Regrds
Barry
Old 06-16-2008, 04:52 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
I've been told 18% of chord length. I'm sure it depends upon the actual shape of the rudder if you want it truly optimized, but it seems these number are 'close enough' for most applications.
Kenneth Grome
Old 06-19-2008, 12:05 AM
diwebb diwebb is offline
Rep: 65 Posts: 120
There is no hard and fast rule, as always it depends on the situation. Can you give a bit more info such as what type of boat is the rudder going on, sail or powewr? Is it a high performance boat or do you just want to reduce the helm forces? For a power boat where feel is not too important the 15 to 18% suggested would be ok, if for a sailboat then I would suggest less so that some feel is maintained in the helm, somewhere between 10 and 14% usually suffices.
rudder design josch Sailboats 39 04-29-2012 06:05 PM
Balanced rudder behind a keel? MikeJohns Boat Design 12 02-12-2006 05:06 PM
Balanced yacht and LCF movement when healed in MaxSurf Mikey Boat Design 2 03-25-2005 06:03 AM
Sail design - balanced lug Robert Miller Sailboats 9 11-30-2004 04:08 PM
Balanced Rudder Design h20land Boat Design 15 04-06-2004 09:08 AM
