| backstay adjuster I search a model of mecanical backsay adjuster home made for a 30 foot sailboat, I have stainless 316L, and welding tool, do you put help me, tanks
__________________ :confused: |
| The easiest, cheapest and lightest system is a block and tackle. Do you need to change adjustment fast?
__________________ Gonzo |
| You may be able to design a pelican hook affair to work on this size boat, though the typical setup like this that is available, may be too small for your rig. You could use a turnbuckle with a wheel welded to the body, swivels at the ends, etc. There is a rather expensive ratcheting thing out there, but the cost, in your case the engineering needed would be considerable. What's wrong with the tackle setup seen on most racers? |
| Hydraulic Backstay Adjuster | Lew Morris | Sailboats | 9 | 04-28-2011 09:54 PM |
| Main Sheet Adjuster | SuperPiper | Sailboats | 1 | 07-31-2004 09:22 PM |
| Backstay | Lew Morris | Sailboats | 6 | 06-30-2004 03:25 PM |
| Roach to backstay clearance | des | Sailboats | 1 | 06-30-2004 06:41 AM |
