Old 10-02-2009, 04:55 PM
jmercer jmercer is offline
Rep: 26 Posts: 6
Axe Bow concept
hey,
I'm new here, so I don't know if this has been a common topic, but from a quick scan I couldn't find much.
I've become very interested, as of late, in the Axe Bow concept. Does anyone know where I can get more information?
I've ready the notes from the 19th HISWA Symposium and from what i can find on design studio sites, but is there nothing more in-depth? Anything helps.
Cheers
Old 10-03-2009, 01:17 PM
apex1
Originally Posted by jmercer View Post
hey,
Cheers
as far as I know only the "Damen" group in Holland is working with ax bows to some extend. But I assume you did know that already!?
http://www.damen.nl/PRODUCTS/DAMEN_F....aspx?mId=8628
Regards
Richard
Old 10-03-2009, 08:15 PM
decoguy decoguy is offline
Rep: 25 Posts: 8
I guess this is what you have already read, but it is interesting reading:
http://hiswasymposium.com/pdf/2006/J.%20Gelling.pdf
Old 10-04-2009, 07:19 AM
gideon gideon is offline
Rep: 10 Posts: 14
we will be using the axe bow concept on our new eco powercat 495 to minimise energy consumption. up to 8 knots very low drag , above that speed the drag raises exponentially
gideon
Old 10-04-2009, 08:13 AM
Rep: 1493 Posts: 7,447
That bow looks like the one in the old bay boats in Virginia and North Carolina.
Old 10-04-2009, 08:23 AM
Rep: 10 Posts: 14
You are right , old warships around the 1920 also used this bow concept is was and is very efficient, just a bit different from a wave piercer but comfortable , low in both wave and parasitic drag. ( up to 8/9 knots for a 49 ft cat )
gideon
Old 10-04-2009, 08:40 AM
Also, the hulls are rather narrow
Old 10-04-2009, 04:16 PM
Gone Ballistic Gone Ballistic is offline
Rep: 10 Posts: 14
My company have recently built a patrol catamaran for the Port of London Authority in the UK. It has limited the axebow concept to just the underwater profile, leaving a raked bow above the waterline for asthetic reasons. As it is operating in the river and slamming is not an issue we also did without the droop bow used on offshore versions to stop the stem emmerging and therefor stop slamming.
The boat was very successful and we hope to start building more of them for the PLA very soon. More details are here: http://www.alnmaritec.co.uk/download...20Guardian.pdf if you're intersted.
Old 10-04-2009, 04:19 PM
I've seen it pass by. It leaves very little wake
Old 10-04-2009, 04:22 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,356
Damen products very sharp looking. Why did the look go out of style and then come back? Seaworthiness or appearence?
Old 10-04-2009, 04:27 PM
It only works on narrow beam hulls. The trend is for fat hulls that have large interiors and carry a lot of people.
Old 10-04-2009, 06:04 PM
Rep: 26 Posts: 6
That is the symposium reference i was referring to yes. Since i last posted i have been in contact with J.L. Gelling who sent me along some information, but basically the same as in the PDF from the symposium. The concept is very intriguing and i will continue to dig further. If i can uncover more i will keep you guys posted.
cheers
Old 04-30-2010, 01:18 AM
Boston's Avatar
Boston Boston is offline
Rep: 1457 Posts: 3,355
I was wondering if anyone can answer this one concerning the axe bow concept
whats the entrance angle that brings a boat into the realm of being defined as axe bow
Im working up a design and have drawn a version that I would think could be called an axe bow configuration
I reduced the entrance angle from about 18° to about 11° by adding a few feet to the bow and I might be able to get it lower still but will need to check a few things before I can say that with certainty
would an entrance angle of 11° be still to blunt to be considered an axe bow
I recently read an article on this that someone presented earlier in the conversation and it was really convincing about the efficiency of the concept but did not define the limitations in shape as clearly as it could have
anyone know the particulars of this configuration
thanks
B
I am skeptical of the deniers diatribe
Old 04-30-2010, 01:51 AM
Mat-C Mat-C is offline
Rep: 109 Posts: 242
Why not simply make the boat longer?
What does the Axe Bow offer that a more conventional shape does not?
I've also wondered why that sharp, deep forefoot isn't prone to broaching...
Old 04-30-2010, 02:21 AM
Boston's Avatar
you should read up on this and then return with some amended questions
they tested for broaching and they tested for a different bow configuration ( wave piercing ) and found the axe bow to be superior
basically they elongated the boat I think one by 25% and another model by 50% and measured the effective changes to vertical motion and to forward resistance
I just would love to see the lines plan of there optimal model
the article does say that a 43~44 m yacht should roughly translate into a 50m axe bow configuration
or roughly a 13% increase in length
I went from a design of 47' and added 5' or an increase of about 10%
I suppose its no big deal to add an extra foot and get it just right but still I'd love to know what there parameters are for a hull qualifying to be regarded as and axe bow
I'm conviced an eskimo style upswept split bow acts like a bulbous bow, but Squidly-Diddly Boat Design 4 08-23-2009 06:08 PM
What's with the axe bow? juiceclark Boat Design 10 07-08-2008 08:24 AM
The Axe Bow is a Revolution... Sean Herron Boat Design 28 05-17-2008 05:03 AM
Strengh of 24 oz woven vs 15.2 oz Bi-axe jfblouin Materials 6 10-06-2005 12:43 AM
Steel roll with Bi-axe jfblouin Materials 0 09-14-2005 05:10 PM
