| Auxillary pontoons for old houseboat The old houseboat I bought has had extra deck space added to the stern and a swim platform . This caused the stern to sag low. To try to remedy the issue the former owner attached 2 36" X 42" X 12" deep plastic floatation boxes using nylon tie-down straps. I want to tryto redo it better. My idea was 2' X 2' X 7' long pontoons made out of plywood and fiberglass tape. I calculated the current floatation boxes are supporting about 400# a piece. I'd want my new pontoons to support upto 800#. My question is, what minimum thickness plywood could I use? I want it to be as light weight as possible. I'd include baffles or braces. Would 1/4" fir plywood be acceptable. Any design recommendations would be appreciated. Thanks, Mark mark8076@msn.com |
| Anyone? |
| Well...2x2x7 will displace 1748 lbs each when totally immersed so each will support 874 lbs at half immersion. With 3 frames of 2x2"s and 1x2 framing at the ends supporting the plywood I would use 3/8" ply for the build. I would also glass the entire outside using epoxy and 12 oz glass cloth. This should be pretty darn bulletproof. Each is going to weigh in at about 75-90 lbs so you are in the ballpark weight wise for 50% immersion. For best results...use 9mm BS1088 marine ply...it will last a lot longer. Steve PS: It usually takes 18-48 hours to start getting replys to posts |
| Building My Own Pontoons | jimith | Boat Design | 22 | 04-06-2008 10:06 AM |
| ? How much do pontoons weigh? | kcleaguer | Boatbuilding | 0 | 09-05-2006 02:52 PM |
| Auxillary Engine 9.9 | James Francis | Boat Design | 0 | 08-22-2005 08:56 AM |
| can pontoons be repaired? | hpy | Metal Boat Building | 8 | 08-11-2005 02:33 PM |
| two ? pvc pontoons | surfstylen | Boat Design | 15 | 06-05-2005 06:46 PM |
