Old 08-22-2005, 08:56 AM
James Francis James Francis is offline
Rep: 10 Posts: 21
Auxillary Engine 9.9
I am in the process of installing a 9.9 and have a question of where to the mount the bracket in relation to the prop/caviation plate depth. I can't mount the bracket where when it is adjusted down the prop and cavitation plate will be fully submerged in the flow of water running from under the hull. Given that it is a small auxillary engine does it matter much if the caviation plate and prop are in the water at the right depth but the bottom of the transom but not in the flow of water?
Thanks
Luhrs T-29 (1995) diesel inboard converted to outboard Iya Boat Design 13 03-07-2007 06:48 PM
gearboxes and potential bobber Boat Design 38 04-03-2005 11:22 AM
Dream Engines Portager Powerboats 55 01-15-2005 05:25 AM
Engine Torque Curves Pat B Propulsion 22 10-06-2004 04:36 PM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 03:06 AM
