Old 08-02-2004, 02:06 AM
mechanical314 mechanical314 is offline
automotive engine -> marine engine????
Thinking about putting a Ford 3.0 V6 (car engine) into a homebuilt 18' runabout. Kinda a replica of a 1930's Century or CC boat. Project is based around ecomony, but not sure how possible this will be.. Any ideas on the cooling system, or opinions on if I should completely scrap this silly idea? I haven't seen much info on converting automotive engines to marine, so any input would be appriciated.
Old 08-02-2004, 04:45 AM
fcfc
I hope power, dimensions ,weight and balance (triming) are compatible with your boat.
An automotive 3.0L V6 should be a beast of at least 400 lbs bare (without any transmission) , and 200 hp. On a 18' boat.
By the way, is it a diesel or gasoline engine ?
How do you plan to transmit power from the flyweel end to the prop ? (clutch, reverse, shafting and torsionnal coupling etc ...)
I think it is more complex than cooling who can frequently be solved by salt water/cooling fluid heat exchanger.
http://www.ejbowman.co.uk/products/pdf/marine.pdf (just the first page found on google)
François.
Old 08-02-2004, 09:47 AM
TheFisher TheFisher is offline
Registered
Rep: 60 Posts: 83
Oh boy, here we go again!
This subject is one that is brought up regularly.
Check this thread. Auto engine marinization
Auto engine marinization DIY Marinizing 231 07-01-2010 08:34 PM
Westlawn School JCFARER Education 59 08-26-2006 07:34 PM
What's the best automotive engine to convert Adz DIY Marinizing 6 08-16-2005 10:01 AM
gearboxes and potential bobber Boat Design 38 04-03-2005 12:22 PM
