Old 04-14-2009, 07:42 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Auto Steering Arm Movement Range
On an auto steering arm, what should the movement range be ? 300mm ?
How much force is expected on this arm... 20 kg's ?
Regards
Fanie
Water ! Just gimme water !
Old 04-14-2009, 08:39 PM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
depends on your boat speed, rudder size, rudder balence, tiller arm length,
working backwards(which is no help) you would need, a pressure gauge in line, ram size and cyl size
from there you would know how much force was needed to shift rudder
shorten tiller arm , smaller distance travelled by ram, and more force needed
all the companies that market these things, give you all you need know, they just need rudder size boat type, max speed
Old 04-14-2009, 08:44 PM
Fanie's Avatar
Fanie
I'm referring to an electro mechanical auto steering
What is required that will work on most sailing boats ? Some of the ones you can buy looks very flimsy to me.
Regards
Fanie
Carbon Fiber Anchor Arm Hostins Fiberglass and Composite Boat Building 1 07-28-2008 01:52 AM
Righting arm curve Mirko Stability 5 08-07-2007 04:46 AM
rhino/righting arm data 3dig Software 7 05-03-2007 03:09 PM
Heeling Arm sorenfdk Sailboats 0 04-15-2005 05:00 PM
Tansom Movement in Vkiking HELP! 46vky Boat Design 6 01-11-2005 07:47 PM
