| Auto pilot systems Doing a search on autopilots seems like taking me back a couple of hundred years. I seem to find only mechanical junk... sorry, auto pilots for boats. One would think a simple electronics processor controlled version would have found the yachting community - of have I just found the wrong links ?
__________________ Regards Fanie |
google up Brookes and Gatehouse, or Furuno, or even ratheon, autopilots |
| Simrad Autohelm www.metalmarinepilot.com www.nautamatic.com Raymarine and I'm sure someone will add more |
| You are stuck with electronics for control, but the best systems are all true hydraulic. Not the yachty setup where the wheel is attached to a pump, and the AP requires repeated starting a hyd pump of 25 or more amps . But the more robust system where the engine supplies hyd pressure , the "wheel" is really a valve and the AP fires 1 amp hyd solenoids to steer. Much easier on the AP to constantly switch an amp than dozens. FF |
| Dix 43b Pilot | ian-edwards | Metal Boat Building | 7 | 09-28-2007 10:11 AM |
| Pilot house - functionality | globaldude | Motorsailers | 32 | 12-08-2006 06:40 AM |
| fiberglass pilot house | sinnfein01916 | Boat Design | 0 | 11-22-2004 07:15 PM |
| pilot 3D-does it only use Nurbs surfaces? | L.DOSSO | Software | 3 | 11-13-2004 06:27 AM |
| Cartwright pilot house designs | Sailboats | 0 | 12-08-2002 10:29 AM | |
