| Attention Quadrajet Experts I've received some good info from this forum about Q-jets in the past, so I figured this would be a good place to ask a specific question. I have two Crusader 270s. The Q-jets are mounted on top of an 8 degree wedge spacer that has four holes in it (one for each barrel). This spacer effectively blocks off the vacuum supply from the manifold to the bottom of the carb, making the power piston and the secondary pull-off useless. Why would Crusader want to do this? Since I do a lot of idle cruising, it seems like vacuum-restricted power piston actuation would be a good thing (for the wallet). I'm considering modifying the spacer but wanted to get some additional thoughts first. Thanks in advance, mike |
| Every engine fed by a Quadrajunk I've ever seen has kind of a 'stumble' just off idle. Maybe this is there to keep things from stalling out when the boat's dropped into gear. |
| Quadrajet carb woes, help! | manzanita | Gas Engines | 8 | 04-19-2007 03:56 AM |
| Quadrajet 17059292 | Silverline | Gas Engines | 0 | 03-26-2007 01:07 AM |
| Quadrajet idle problems, please help... | scotttanner | Gas Engines | 12 | 08-22-2006 01:37 PM |
| Quadrajet Adjustment | ChillrMn1 | Propulsion | 53 | 06-25-2006 06:27 PM |
| Attention Newbies!! | phillip | Fiberglass and Composite Boat Building | 7 | 04-29-2005 04:35 PM |
