| asymmetrical fin Hello all, Where would I find a drawing/ offsets for a asymmetrical fin section? Peter |
| Now I have too many choices, What would be a common section used? Peter |
| Foils sections selections are based a several variables. What is your target Reynolds number range? |
| chord length .5 Mt. speed 3 Mt. a second Renolds number approx 100,000. Does that sound right? Peter |
| Okay, now what do you want this foil to do? It's application? |
| one of a pair of bilgeboards. Peter |
| That's not telling me much. What level of preformance do you desire? What make, model and year boat? Are there specific needs or issues you're looking to solve? What where the previous sections employed and why didn't you like them? Etc., etc., etc. |
| I am looking at replacing an existing lifting fin with 2 bilgeboards. The object of the exercise is to free up floor area in the cabin. lifting bilge boards would be built into bunks so floor area will be clear. The main reason for seeking a efficent section is minimise size and maximise lift. Peter |
| Well you still haven't told me much, so I'll just offer up some sections that preform well at low Reynolds numbers and you can research them and pick the one you like. Naturally, the first one would be the bench mark E387, next on the list would be the FX 63-137, followed by the SD 7003 and SD 7037. Then again you can fall back on one of the NACA 63 series like the 63-209 or try the Selig S3021. |
| Thanks very much for the info. Peter |
| Lets put an Asymmetrical Spinnaker on a Topper! | dylantorquerol | Sailboats | 22 | 09-02-2010 10:40 PM |
| Asymmetrical hull using Maxsurf Academic? | mystrwizard | Software | 3 | 11-22-2009 05:58 PM |
| Modifying shunting proa asymmetrical hull? | mystrwizard | Boat Design | 3 | 10-26-2009 09:28 PM |
| Loads on an Asymmetrical Spinnaker Pole | mww195 | Boat Design | 4 | 01-21-2006 01:41 PM |
| Asymmetrical+Foil vs Symmetrical Multi | skypoke | Boat Design | 13 | 08-21-2005 07:42 PM |
