Old 06-08-2004, 12:55 PM
JOHN P. JOHN P. is offline
Rep: 10 Posts: 19
Armstrong Bracket More Questions
Well, I finally got the bracket mounted, and the motor at the correct height. The question I have is with a 17 pitch prop I was ventilating when the boat was on plane at top speed (29mph). I switched the prop to a 19 pitch prop and it greatly reduced the ventilation but there is still some at top speed. Do I live with this or is there anything else that can be done. I don't really want to install a Jack Plate, but thought about oblonging the top two mount holes as the lower holes are slotted. This would allow me to drop the motor some. I'm guessing that I need to go about half the distance between holes or 10mm.
Old 06-08-2004, 01:53 PM
mmd's Avatar
mmd mmd is offline
Rep: 306 Posts: 378
How about installing a larger, aftermarket cavitation plate?
Old 06-08-2004, 02:26 PM
Rep: 10 Posts: 19
[quote=mmd]How about installing a larger, aftermarket cavitation plate?
What would that do and who makes them?
Transom Bracket on a 19ft boat CapeCodder Powerboats 6 12-07-2011 09:30 AM
Some Newby Questions Silenti Sailboats 18 07-10-2005 09:12 AM
Motor Position Armstrong Bracket JOHN P. Powerboats 5 06-22-2004 07:16 PM
Armstrong Bracket BOAT PROBLEM JOHN P. Powerboats 0 05-11-2004 04:38 PM
Outboard Mounting Armstrong Bracket Guest Powerboats 1 11-22-2003 07:06 AM
