Old 06-08-2004, 08:04 AM
Area calculations
Is there a simple way to calculate the area of tanks (ballast, fuel oil, etc.) of merchant ship without calculating the exact area of each frame? In other words is there an approximate formula for calculating the area of the steel in a tank based on the volume?
Thanks
Old 06-16-2004, 10:50 AM
Zed
Use Simpson's Rule for numerical integratio.
Cheers
zed
Old 06-18-2004, 09:43 PM
Rep: 572 Posts: 646
Merchant ships ask for precise work. That explains the price of the engineering studies, calculations and plans of the work boats....
Normally a good CAD will give you all the surfaces. By hand it's better to use differents systems depending on the shape and location of the items, but there is not a esay fast way. It's long, tedious, boring and absolutely necessary.
BassBoat Drain area, below transom rot HELP!! northrivergeek Powerboats 4 12-12-2005 07:06 AM
Wetted surface area - approximate formulas Mike D Boat Design 11 08-25-2005 11:00 AM
Curve of area...Stu Turner Boat Design 0 03-29-2005 02:08 PM
Building a heat exchanger into the hull djackson99 Powerboats 42 03-21-2005 02:15 PM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-25-2002 11:26 PM
