Old 10-22-2011, 09:49 PM
Squidly-Diddly Squidly-Diddly is offline
Rep: 193 Posts: 706
anyone slapped an outboard or oars on Hobie 16 or similar cat?
Sometimes you just don't want to sail.
I've also noticed Hobie HULLS are often on offer for free, or near free.
Anyone made a adapter-backet to clamp onto the big piece of alumimum tubing and used a small outboard to make a Hobie into a motorized platform for fishing, birdwatching, etc?
Hobie-Cat Motor-Sailor?
How about a set of oars, and probably a big ice-chest for a elevated seat.
Maybe one of those big chests with 4 wheels and a couple 8' x 1' x 1" planks on the tramp for "sliding seat rower". Sure, might hobby-horse a bit.
Old 10-23-2011, 02:01 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
http://cheatabrackets.com/page6.php
Old 10-23-2011, 03:18 AM
Rep: 1493 Posts: 7,447
They use Hobie Cat hulls with outboards in many rowing clubs for the coach to follow the boats.
Old 10-23-2011, 10:02 AM
philSweet's Avatar
philSweet philSweet is offline
Rep: 658 Posts: 621
There have been dozens of fiberglass bridgedecks made to convert Hobies into dive boats, sponge boats, drug boats, chase boats, maintenance barges, gunning boats, you name it. Some were one part and others were quite fancy with four or five molds and a bit of assembly required. Unless big surf is a real concern, I've always thought the Hobie 18 was a better prospect because the hulls have a bit more bouyancy.
Old 10-24-2011, 09:39 PM
upchurchmr upchurchmr is offline
Rep: 224 Posts: 526
philSweet,
Do you have any pictures or links to such bridgedecks? I personally have never seen one.
But I do agree the 18 would make a better boat, with my preference being a Tornado (even bigger hulls).
Marc
Old 10-24-2011, 11:24 PM
philSweet's Avatar
Rep: 658 Posts: 621
I went looking when I originally posted but didn't find any in the first five minutes. I think it must be a bit dated (as in before digital cameras and internet). I have seen at least six different arrangements in Florida. None of the stuff was anything to write home about, either. The fussy one probably used some parts and molds already lieing around, I was kind of amazed any one had bothered. Or maybe it sort of grew over the years. Everything I've seen would have been on the water by 1980.
Old 10-25-2011, 05:01 AM
Rep: 205 Posts: 442
Professional Boatbuilder magazine has a story about Russel Brown and it featured his "pod cat" made from a pair of tornado hulls. He had like a 14ft skiff suspended on pylons coming off the hulls with like a 20HP OB. Was pretty cool, and take a look here:
Tornado hulls with 25 etec.. Need design help.
Steve
Old 10-28-2011, 04:42 PM
Tiny Turnip Tiny Turnip is offline
Rep: 536 Posts: 256
I converted a Dart 18 to pedal power, and it makes a seriously practical boat for fishing, dropping a few creels, swimming, picnicking, camping etc. Cruises all day at 4knots without getting out of breath. I'm chuffed to bits with it. Picked up the Dart with full rig and road trailer for 600 quid... I can dig out some pictures if you're interested.
Old 10-29-2011, 10:10 AM
Rep: 193 Posts: 706
Tiny, I'm interested in the pics, please post.
How does it handle mild wind and weather cocking?
Old 10-30-2011, 02:49 PM
Rep: 536 Posts: 256
Pedal conversion of a Dart 18
Here are some pictures of Fangle, my pedal powered conversion of a Dart 18.
I chose the Dart in part because the cross beams were straight, and made the conversion easier. I bought reconditioned seacycle units, plus their mounting brackets, which I attached with stainless steel plates to the front ends of two longitudinal beams. I slung these beams beneath the Dart cross beams with U bolts. I replaced the trampoline with three ply panels, which were bolted down to the longitudinal beams, and supported by the extrusion which took the edge of the tramp down the inside edges of the hulls.
The steering is achieved with a simple system of ropes and pulleys underneath the deck.
The seats are from a Trice recumbent bicycle, with a ply base.
The ply deck provides a substantial stable platform about 7 feet square. The boat is completely without weather protection; as the available power is so low, I thought it crucial to keep the windage to a minimum.
We have played out in a Force 6, in reasonably sheltered water, and I wouldn't want to push it beyond that. It felt like there was a slight tendency to broach when surfing down waves, which I don't fully understand, but it wasn't a strong effect.
You can see Sally in one of the pictures, who is well into her 70s, managing admirably.
4 knots all day cruising speed. 5.2ish flat out. One of the most pleasing aspects is the control for close manoeuvreing - great for fishing.
anyone slapped an outboard or oars on Hobie 16 or similar cat?-gigha-2009-128.jpg  anyone slapped an outboard or oars on Hobie 16 or similar cat?-gigha-2009-202.jpg  anyone slapped an outboard or oars on Hobie 16 or similar cat?-gigha-2009-139.jpg
Old 10-30-2011, 11:33 PM
Poida Poida is offline
Rep: 395 Posts: 1,072
I put an outboard motor on a surfcat, attaching it to a transom I put on the rear part of the frame.
I used the turning mechanism of the outboard to try and turn but ended up going in the same direction sideways.
You have to fix the outboard so it doesn't turn and use the original rudders.
Old 11-01-2011, 10:35 PM
spidennis's Avatar
spidennis spidennis is offline
Rep: 116 Posts: 451
What is your speed with only one "engine"? And can you go for several hours or possibly all day like this?
Old 11-01-2011, 10:37 PM
spidennis's Avatar
Rep: 116 Posts: 451
I'm also interested in the oars idea .......
hadn't yet tried it out myself.
the ergonomics might not be all that good?
Old 11-02-2011, 02:39 AM
Rep: 536 Posts: 256
Its about 3.2 with one engine, cruise all day.
Old 11-02-2011, 06:50 AM
spidennis's Avatar
Rep: 116 Posts: 451
pics of rowing a hobie:
https://picasaweb.google.com/Norm742/HobieWaveRowing
here's a thread about it:
http://www.hobiecat.com/forums/viewtopic.php?f=9&t=4324
from the pics it does appear possible.
I notice the sag in the tramp to lower the "engine" for a better angle.
I can imagine that sitting up too high would mess up the ergonomics?
Beach, hobie or sail-cat colo Multihulls 1 06-15-2007 11:40 AM
Hobie Cat 18 Sail Plans stuartegnal Boat Design 0 04-03-2007 01:47 AM
Hobie Cat Information Site MyVision Sailboats 0 06-25-2006 09:22 PM
Old hobie cat rigging, new boat. MattBentti Sailboats 43 05-14-2006 03:53 PM
Hobie Cat Snubber Multihulls 8 02-13-2006 09:10 AM
