Old 07-28-2005, 10:42 PM
JonathanCole's Avatar
JonathanCole JonathanCole is offline
imagineer
Rep: 58 Posts: 436
Any experience with polyethelene hulls?
Polyethelene Hulls are said to be virtually indestructible and maintenance free with a high degree of finish and some even offer a lifetime warranty. Does anyone have any experience with this technology or the comapny that developed it? http://www.genmar.com/page.cfm?id=42
Old 07-29-2005, 12:57 PM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
polyetheen or PE you mean? a thermoplast? carver is using it for hulls? make me stand corrected or shoot me to the moon please!
Old 07-29-2005, 01:24 PM
imagineer
Rep: 58 Posts: 436
Oops, spelled it wrong. Polyethylene. See Rotolene (trademark) hulls in the Genmar web site. Also found some info in the materials forum.
Morrelli and Melvin, top designers,
( http://www.morrellimelvin.com/gj65_photos.html )
have designed a tri hull pontoon boat for Genmar made from thermoplastic polyethylene and baked in an oven while rotating.
Old 07-29-2005, 02:41 PM
yipster's Avatar
ok, USCG Certified means something, new techniques used i guess but havent touched that yet.
thermoplastic's are good for many things but for good hulls their new to me.
i know small bathtub boats are made from PE but bend, bleach, crack, split without repair.
but wait, you say polyetylene, i'm no expert and have to dig up my polytechnic books...
anyone around here with wiser remarks?
Old 08-01-2005, 09:17 AM
fx152 fx152 is offline
Rep: 10 Posts: 3
The new-marine guys have been doing beach catamarans in PE for some time now.
I think they also use the rotomolding process.
I've sailed an old rental once and the hulls were still ok.
Cheers,
Old 08-01-2005, 10:11 AM
Sander Rave's Avatar
Sander Rave Sander Rave is offline
Rep: 59 Posts: 201
It's a perfect material and basicly indestructable. Something for Dinkytoys or rentals...
You'r limited to the size of your molds. I did lots of products with PE and rotomolding.
I would use it only for a dinghy, rentals and other stuff that has durability and economics above performance.
Great material, great opportunities if used in the right way (initial costs are pretty high namely in moulds so you need to have perspective on selling numbers)
regards,
Sander
Sander Rave
SkottKarra industrieel ontwerpers
skottkarra.com
Old 08-01-2005, 10:42 AM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
Is it light weight?
Does it expand a lot or a little due to temperature changes?
Does it produce less condensation than a metal hull due to it's insulatings features........or is the "due point" in the walls and what havoc does that create?
Old 08-01-2005, 04:05 PM
yipster's Avatar
interesting, but is it still a thermoplast like say a bucket?
Old 08-01-2005, 04:31 PM
icetreader icetreader is offline
Rep: 12 Posts: 189
I use Polyethylene for my boats. It's extremely tough and generally I have only good things to say about it but I wouldn't go as far as saying it's indestructible...
There's a thread about HDPE (high density PE) in the "materials" forum.
Yoav
fishing kayaks
Old 08-01-2005, 06:27 PM
CT 249 CT 249 is offline
Rep: 322 Posts: 1,170
We still sail the original Windsurfer One Designs (the very first windsurfer) as a class down here. They are much flexier and about 20% heavier than "normal" plastic construction and about 50% heavier than carbon. But the durability is incredible. Boats close to 20 years old and heavily used are still fully competitive against the former Olympians at the front of the fleet. Like those PE Optis, they just keep on lasting. PE Toppers in the UK are the second-biggest class.
IMHO the PE boats, when they get a bit cheaper as moulds expense is ameliorated and second-hand boats become available, will really revive the slower/cheaper end of sailing. You'll be able to waltze into one for not a lot, get some good OD racing and sell it for little loss.
Old 08-02-2005, 02:57 AM
Rep: 59 Posts: 201
True Icetrader,
In normal use I mean.
Expansion is high, like any plastic
It's a thermoplast like any.
HDPE is lighter than water, and can be moulded, machined, and joined together using welding (difficult to glue).
What I also like: It's a good material to recycle
for additional information folow this link:
http://www.lgpetro.com/eng/product_i...duct/hdpe.html
grade: MC6001
you should see this production method like a BBQ: a mould on a grill, filled with some PE and rotated like a turkey or cow
Sander Rave
skottkarra.com
Old 08-02-2005, 07:23 AM
Rep: 1493 Posts: 7,447
There is a company in North Carolina rotomolding powerboats up to 18'. They look Ok. I believe it is the biggest rotomolded object being manufactured. http://www.triumphboats.com/
Old 08-02-2005, 07:32 AM
yipster's Avatar
new chemistry and techniques used i guess, my ( older ) books mention hard PE is not scratch resistant, oils eat it, used for crates and buckets etc. i rowed small double shelled PE dingy's, seen torn ups and still got to be convinced...
http://en.wikipedia.org/wiki/Polyethylene
Old 08-02-2005, 09:07 AM
Rep: 12 Posts: 189
PE can be scratched, but what material is totally scratch resistant?...
My experience with PE is that it resists oil-based solvents very well.
It's only natural that good materials find uses in a wide variety of applications -after all steel is used in products ranging from sewing needles to submarines
Yoav
fishing kayaks
Old 08-02-2005, 09:14 AM
yipster's Avatar
guess i / we are lost in the wonderfull world of chemics. just checked UHMWPE that got me impressed allright.
HDPE resists many chemicals, not oil and fat based solvents very well.
The Ideal Cruiser - a long range passagemaker D'ARTOIS Projects & Proposals 306 07-15-2011 06:54 AM
ROCAT closed mould one-piece hulls cristofa Fiberglass and Composite Boat Building 10 07-15-2005 04:13 PM
Experience with building from Carlson Hulls design? BCBoater Software 3 11-12-2003 09:21 AM
A Tale of Two Hulls.... BCBoater Boat Design 6 09-05-2003 01:48 AM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-25-2002 11:26 PM
