Old 06-14-2011, 05:11 PM
Squidly-Diddly Squidly-Diddly is offline
Rep: 193 Posts: 706
any 3rd World Windmill (land-bases) designs?s
I've seen a few ideas for boats for 3rd World here, but how about some sailing rigging expertise to design a land-based windmill?
I'm thinking of something that could be constructed of any sticks or linear material and use any sort of fabric(or thatching) and most likely run a generator/altinator of automotive origin, with possibility of running more than one off the same windmill.
Hopefully, it would be semi-self regulating/flurring/trimming, maybe with a weight on a rope to regulate amount of force being transmitted and/or trim the sails to acheive higher RPMs in lighter winds.
The tricky part would be figuring out a super-low tech method of trimming the sails while they are in motion. Maybe a gate where their relievant parts get adjusted on each revolution?
I'm thinking of something about 20' tall with the post secured by trianglation of 3 ropes.
Gearing it up is another big problem as I imagine the windmill would be turning at approx. 60RPM but an automotive generator wants 1000s of RPMs. Maybe a large diameter crude pulley on the windmill driving a rope which would be tensioned by a weighted pulley?
Old 06-14-2011, 06:42 PM
Rep: 1493 Posts: 7,447
Just look at any old windmill. There is no need to reinvent the wheel.
Old 06-14-2011, 07:38 PM
Poida Poida is offline
Rep: 395 Posts: 1,072
Your right Gonzo, and there's no point in reinventing the windmill either.
Australia's full of windmills. There is no need to change the angle of the blades, as they are set to the worste conditions so they are really good in the best conditions.
For electricity they normally charge batteries so the speed of the windmill isn't changed, the current is electrically regulated.
For water, any excess water, when the tank is full, is drained back down the hole it came from, recycling.
Windmills are better manufactured in an industrial area as they can be completely disassembled and transported to site. However for water you need a hole in the ground, bit of a problem.
And electrcity in a 3rd world country isn't much good because you can't eat electricity.
Old 06-16-2011, 05:42 PM
aka Terry Haines
Rep: 1811 Posts: 3,006
Some info on Wiki http://en.wikipedia.org/wiki/Windmill
Images old and new here http://www.google.ca/search?q=windmi...w&ved=0CGMQsAQ
Dances with Turkeys
Old 06-16-2011, 06:18 PM
What I like about old windmills is that they are made out of sticks, sometimes brick or stone and natural fiber sails or wooden slats.
Old 06-16-2011, 08:36 PM
masalai masalai is offline
masalai
Rep: 1689 Posts: 7,507
Much of the "third world" I have seen both personally and researching for stuff on the web is adequately serviced locally, yet still arrogant fools still try to deliver technology and scale up for "efficiency", without researching that, "that is just overkill and not worth-while" - (Yes put it - we will then have something to sell that is really useless for our situation...)
Try to be helpful...
Remember that there are at least two sides for every story...
Old 06-17-2011, 02:01 AM
Boston's Avatar
Boston Boston is offline
Rep: 1457 Posts: 3,355
go with a vertical axis turbine that you can make out of old barrels and a car alternator. Really primitive and parts are everywhere
check out
these turbine alternaters are easy to make
I am skeptical of the deniers diatribe
Old 03-06-2012, 02:37 AM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1816 Posts: 1,422
check out
They are certainly cheap to build, but they are not very efficient. Being drag
devices they also need a very strong support structure.
Here's an extended version of a paper on another vertical axis device that
was published today in the journal "Renewable Energy":
http://www.cyberiad.net/library/pdf/...feb%202012.pdf
The published shorter version is at:
http://www.sciencedirect.com/science...60148112001395
Boat shapes and designs from all over the world ! Vulkyn Powerboats 11 10-01-2010 01:35 PM
Windmill in the Roaring Forties Wendy Boat Design 5 11-07-2008 02:16 PM
Design of a Land Sail/Land Yatch Aeronaut Boat Design 8 09-21-2007 04:36 PM
3rd log on pontoon Bowtie41 Boat Design 0 07-12-2006 11:34 PM
3rd Annual Propeller Seminar Don MacPherson Press Releases 0 12-08-2004 01:07 PM
