Old 07-01-2009, 09:40 AM
issac82 issac82 is offline
Rep: 6 Posts: 31
anchoring in deep waters
can anybody guide me which type of anchor or sinker is better to hold a boat around 200tons in watwers of around 150m depth?
Old 07-01-2009, 09:41 PM
masalai masalai is offline
masalai
Rep: 1630 Posts: 7,321
This begs a stupid answer - one that floats?... but seriously if your 200 ton boat is inadequately fitted out for such, then maybe it is inappropriate? for me to have answered.... Hope someone comes along to help you resolve your conundrum...
Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story...
A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy...
Old 07-01-2009, 09:52 PM
Rep: 472 Posts: 1,391
A big Anchor
Old 07-01-2009, 09:58 PM
masalai
and a chain with a looooong rope (rope end attached to the boat?)
Old 07-02-2009, 01:41 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1514 Posts: 5,518
I feel the same as you guys. Is this a joke.
Go one then Ille bite. A boat your size will have an anchor made for it. It is on the bow or in ahole in the side. using this one would be appropriate.
For 150 meter you would need half a kilometer of chain. At least.
150 meter of chain and an anchor will be a lot of wieght on your winching gear.
Normally you would not anchor in such depths but go for something like 15 meter.
If you don't know how to anchor a 200 ton boat what are you doing with one
Old 07-02-2009, 02:58 AM
wardd wardd is offline
Rep: 443 Posts: 925
you wouldn't need much chain if you sank the boat
Old 07-02-2009, 02:03 PM
peter radclyffe's Avatar
peter radclyffe peter radclyffe is offline
Rep: 561 Posts: 1,052
you need a very powerful winch, to pull twice the weight of chain you have out
Old 07-02-2009, 05:24 PM
masalai
as I said before, a floating anchor and now to add - a sinking boat...
Old 07-02-2009, 06:13 PM
apex1
The weight of the boat in tonnes is the weight of the anchor in Kg, the chain is sufficient if three times the depth, perfect if four times. If chain only, and at 200 tonnes it IS chain only, no ropes. Anchoring on 150 meter depth is idiotic, so you can skimp on the chain calculation. But move the boat closer to shore, there it could make sense to calculate the chain.
Good luck
Richard
Old 07-02-2009, 07:03 PM
masalai
Gee apex, and we were just warming up for a bit of sarcastic "fun"
Old 07-02-2009, 07:11 PM
Good luck
Richard
at what tonnage does this start
Old 07-02-2009, 07:47 PM
apex1
What Peter?
Mas. read between the lines, I am from the north, sarcasm is a decent one there!
Old 07-02-2009, 09:25 PM
Frosty's Avatar
[Weight of the boat in tons is the weight of the anchor in KG.]
Mmmm let me sit down and think about that for a minute.
lets see now my boat is 14 tons --so that 14KG----14KG??????
Thats 28 pounds ????? Hmmm
Old 07-03-2009, 12:16 PM
apex1
Not toys Frosty, boats! And I only apply that rule from about 50 tonnes up to approx 250. Above we have a lower, beneath a higher percentage.
Old 07-03-2009, 12:44 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
And rightly so, Richard.... by the "1 kg/t" rule, my runabout should be able to hold just fine on an anchor about the size of a large coffee mug
Isaac, "mydauphin" got it right off the bat- you need a big anchor.
How big? Well, there's a reason no anchor manufacturer provides standard recommendations for boats this big. Above 100 tonnes or so, you start encroaching on the turf of a large, lumbering animal known as a "Classification Society". If you're going to play on their turf, you're expected to play by their rules- thousands and thousands of pages of rules. Rules to cover just about everything. Including anchors.
Deepest Anchoring mydauphin Boat Design 47 04-11-2009 04:50 AM
Anchoring tackle Patrick BLOSSE Boat Design 1 08-15-2007 06:03 PM
International waters SWG Open Discussion: All Things Boats & Boating 13 10-01-2006 12:53 PM
Proper anchoring mariner 40 Open Discussion: All Things Boats & Boating 8 02-22-2006 05:56 PM
Anchoring Guillermo Open Discussion: All Things Boats & Boating 0 10-15-2005 08:08 AM
