Old 11-21-2010, 02:15 AM
milad.naval milad.naval is offline
Rep: 23 Posts: 8
Anchor design
Hi,
I have got a university homework that I should choose an anchor for a composite boat. I calculated the equipment number (E.N=21) with dnv rule for hsc but I can't found the suitable anchor because it's not included.Could any one help me?
Thanks a lot.
Old 11-21-2010, 09:46 AM
Rep: 1493 Posts: 7,447
What is equipment number? Anchors are selected according to sea/wind conditions and type of bottom.
Old 11-21-2010, 11:20 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
The bottom type is crucial. Rock, mud, sand, shale, heavy weeds or kelp cover...
-Tom
Old 11-21-2010, 04:56 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Gonzo, you said that you are a surveyor?.......Equipment Number is a calculation that takes into account the profile of a vessel in relation to its above waterline areas and its displacement...have a look at your standards for say, Lloyds. It will be described therein.
Old 11-22-2010, 11:18 PM
Rep: 23 Posts: 8
hello,
thanks for your replies,i calculated equipment number by dnv, it is 21 but my problem is that the equipment number is fewer than base equipment number that dnv mentions on it. the base equipment number of dnv is 30,i think bottom type is sandy.
thank you all.
Old 11-27-2010, 08:57 AM
Craig Smith's Avatar
Craig Smith Craig Smith is offline
Anchorsmith
Rep: 10 Posts: 2
Originally Posted by milad.naval View Post
Hi,
Thanks a lot.
Are you required to meet DNV Rules for your vessel or are you just assuming this is the appropriate way to proceed? It seems like a small boat to be going through certification.
If you require adherence to Rules, then as you are aware they typically do not provide anchor sizing for EN < 50. They're generally not interested in certifying anchors much under 100 kg. However, the Rules say that you can interpolate sizes for EN #s not listed in the tables. For an EN of 21 you might therefore get:
- A standard anchor of 76+ kg, or
- An HHP anchor of 57+ kg, or
- An SHHP anchor of 38+ kg
You would have to get the classification society to agree with this rationale.
If you don't require classification then the above is a decent guide to start with, but you should probably make your own decisions based on the properties of the boat. For advice from the likes of Rocna they would want to know the LOA and displacement of the vessel. For example consider their sizing advice:
www.rocna.com/kb/Rocna_sizing_recommendations
Craig Smith
Old 11-27-2010, 05:21 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
I was under the impression that Ford engines makes the best anchors for any conditions and bottoms...
Modern anchors makes for superior holding as Craig advised, Rocna is one of them.
Regards
Fanie
Water ! Just gimme water !
Old 11-28-2010, 01:08 AM
Rep: 670 Posts: 2,457
Ford engines the best anchors..YOU CRAZY !!! youre gonna loose your boat, everyone knows Mercury outboard motors have twice the holding power and neatly nest on your stern rail when not being used in anchor mode .
Old 11-28-2010, 04:27 AM
Rep: 23 Posts: 8
Thank you Craig Smith
Old 11-28-2010, 05:08 AM
Alik's Avatar
Alik Alik is offline
Rep: 1070 Posts: 2,035
Take any equioment catalog, say Westmarine, and choose from there depending on length. Equipment number is too formal way to choose anchor for such a small boat.
Old 11-28-2010, 11:59 AM
Rep: 501 Posts: 1,767
Northill was and is the best anchor for its size. They are hard to get however.... I am sure many will disagree. Danforths are not worth the metal they are made from.
Old 11-28-2010, 12:05 PM
Mariner
Well that's a pile of stinky. My 14 pound, used danforth was $20US and out of the six styles I've used in this area, is the absolute best.
What ground material are you anchoring in mydauphin?
-Tom
Old 11-28-2010, 12:11 PM
Both Danforth and fisherman are very valuable because they store flat. This means you can carry a huge danforth as a backup, kedge.
Old 11-28-2010, 12:58 PM
garydierking garydierking is offline
Rep: 156 Posts: 87
I agree about the Northill, but are they still produced?
Old 11-28-2010, 01:01 PM
I rarely see them. Great anchor. . They are difficult to store on the stem. Perhaps google it.
Anchor Design monjure Boat Design 3 01-17-2010 11:12 AM
Parachute Anchors, Para-Anchor, Sea Anchor brian eiland Boat Design 28 05-06-2009 02:11 AM
Anchor Handling Tug/Supply vessel design zaim_2102 Boat Design 0 04-27-2009 09:21 PM
anchor and anchor winch questions martinf Boat Design 7 04-05-2008 06:10 PM
Future of the anchor design Drago Open Discussion: All Things Boats & Boating 50 02-07-2008 01:24 PM
