Old 01-15-2011, 05:53 PM
Downtown Downtown is offline
Rep: 10 Posts: 13
What would you suggest for two tanks on each side of the bilge approximately 48 x 24 x 24. I know other trawlers like mine have replaced their tanks this way. I know it is a lot of tankage, but, as you know, these are designed to be long distance motor yachts. I don't want to lesson the value of the vessel by not having close to normal fuel capacity for a trawler. Can't they be designed to be tied together with piping rather than hoses?
Old 01-15-2011, 06:53 PM
fishinAK fishinAK is offline
Rep: 10 Posts: 5
hmm lots of good ideas here. Still cant find a place to buy a plastic tank that has an 80 gal capacity or will build to my spec dimensions? any ideas?
Has anyone had any experience with the fuel bladders as gas tanks?
Old 01-16-2011, 12:18 AM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
Piping does not change the fundamental problem but its your boat.
Tom Lathrop
Old 01-16-2011, 12:31 AM
Rep: 10 Posts: 13
Thanks, Tom.
Old 01-17-2011, 10:25 AM
Bruce46 Bruce46 is offline
Rep: 49 Posts: 81
The Coast Guard frowns on connections on the bottom of any fuel tank. For diesel I would consider using a day tank and a transfer/ fuel polishing system to keep your fuel clean and engine happy. (Clean fuel helps reliability greatly) I'd be tempted to go with epoxy coated steel tanks as steel can cope better with acids etc.
Old 01-17-2011, 03:05 PM
alaskamokaiman alaskamokaiman is offline
Rep: 13 Posts: 59
The cross linked poly tanks will be going away if the EPA has anything to say. All the red gas cans will be gone, they want us to use nylon to build the tanks. Nylon is not a good material as it is brittle.
You can call Ben at Silver Streak boats in Anchorage to get costs to build the tanks you want.
Installing Aluminum Gas tank Jack Jr. Fiberglass and Composite Boat Building 8 03-16-2010 12:18 PM
Gas tank cleaning isby Powerboats 2 08-23-2006 08:46 PM
Converting gas tank odysseus Outboards 0 06-11-2006 02:12 PM
water in gas tank chuck mc Open Discussion: All Things Boats & Boating 18 12-07-2005 03:51 PM
Is Aluminum Gas Tank Ok ???? MATTRESS GUY Boatbuilding 3 02-07-2005 12:18 PM
