| Aluminum dinghy/life raft... I have recently seen a plastic molded dinghy/liferaft with sailing attachments. I really like this idea but I like aluminum better. Am wondering if anyone has seen anything like this in aluminum? With an aluminum sailing/rowing dinghy which doubles as a life raft, more space is available on deck, you know that your life raft is going to work when you really need it, 5086 aluminum is durable and virtually maintenance free and initial costs are less as 1 boat does the job of 2. I understand the safety limitations of a dinghy VS a true life raft in the scenario of launching and righting the thing in nasty weather but the ability to sail a life raft is very appealing to me. Thoughts please… |
| I do not see the advantage of an aluminium dinghy compaired to a plastic one! I do however see the advantage of being able to sail your "liferaft". Having read several books on survival at sea, the ever re-occuring remarks are that the liferaft is prone to leaking, always to small and there is the danger of rolling. Eventually it al boils down to the amount of space available on deck, preparation of the journey and being able to launch the dinghy when you need it! The survival package that's normally in the liferaft has to be placed in the dinghy and has a higher risk of being damaged as the dinghy is used more often!
__________________ Dutch Peter “The opinion of the majority is not necessarily correct” – Yi Qing Cui |
| Aluminum doesn't get brittle in sunlight, is easier to attach stuff to, and is easier to repair or modify. It also holds up better when dragged over rocks, gravel and coarse sand. Aluminum is cheaper than most composites. I prefer aluminum for small boats, but it's hard to find certain types of boats in aluminum. I would love to build a Tornado catamaran in aluminum if I were more ambitious. http://www.google.com/search?num=100...es&btnG=Search But then... copper would inhibit marine growth w/o antifouling paint.... I wonder if anyone ever made a Cu-Al alloy? |
| Look for plans designed for plywood, especially stitch and glue. The same panel shapes can be used for sheet aluminum. Steve |
| Bonding Aluminum with Epoxy | Chris Krumm | Materials | 49 | 02-10-2012 05:16 AM |
| Welders ?!? (Aluminum) | DHN | Boatbuilding | 89 | 07-20-2009 09:37 PM |
| Easiest (i.e. cheapest) way to build a raft + rafting disaster! | Spyder Ninja | Boatbuilding | 31 | 02-20-2009 10:58 PM |
| installing aluminum gunwale | lumie | Metal Boat Building | 1 | 09-07-2005 10:20 AM |
| Structural Foam for Aluminum Hulls | jprev | Metal Boat Building | 3 | 08-30-2004 09:51 PM |
