Old 08-08-2007, 07:51 PM
Alik's Avatar
Alik Alik is offline
Rep: 1070 Posts: 2,035
Aluminum boat - painting with laquer
Need to paint aluminum boat, but would prefer a kind of transparent paint or laquer, so can see the metal. Just wonder if there is something available on the market. Thanks!
Old 08-08-2007, 07:53 PM
USCGRET/E8 USCGRET/E8 is offline
Senior Chief
Rep: 41 Posts: 164
To get it to stick, it would mostly have to be a two part paint like for aircraft.
Old 08-08-2007, 08:23 PM
lazeyjack
yes devoe make one, there are a few around, this one lasts a very long time, write to www.bladerunnerboats.co.nz
The method is this, sand it hard with 100 grit in an orbital sander, then acid wash, fast foaming, then let dry and apply the stuff, looks great
Another thing you can do is after the wash put aladyne on applied by plastic garden spray, stops oxide and looks bronzy, used on all mine and also on aircraft prepaint
Old 08-08-2007, 08:59 PM
Senior Chief
Rep: 41 Posts: 164
If you want to easily brighten things up, try some Alumabrite
Old 08-08-2007, 09:40 PM
lazeyjack
by the way Alec, that is a very very nice entry on this boat, who designed lines and where was she built, you can see by my galllery that I specialise in the medum, so I'm interested
Old 08-08-2007, 09:47 PM
Alik's Avatar
Designed by us, built by BPMarine (Thailand).
Old 08-09-2007, 09:18 AM
Alik's Avatar
I have put some info on the boat here:
http://www.amdesign.co.th/design_xp980.htm
Old 08-09-2007, 03:04 PM
lazeyjack
yes her bottom is identical to how I do mine, but the two topside panels are hansome indeed, I just put a D6 in one of mine in NZ, THE 310 VERSION
I,m glad you don't use strakes, which really harden the ride
i use 400 deep girdars full length ex in E/R 600 apart with fully welded foors 600 spaced, and 6mm bottom, I gave 5 years warranty on the hull and they have all run out without a call back, it's very rough off the NZ coast
Old 08-09-2007, 03:06 PM
Rep: 749 Posts: 1,314
I have had good results form DuPont Imron over bare aluminum. That is a two part automotive paint that is very durable. Apparently all two part urethanes are not equal. The DuPont stuff is expensive, it resists attack from some chemicals very well. I can not vouch for its' ability to withstand salt air and water. Resistance to UV degradation is good. Availability in Thailand may be problematic.
Boat painting (custom color) thefuture Boat Design 4 03-29-2007 04:41 PM
Advice on painting fiberglass boat ZukiJon Fiberglass and Composite Boat Building 5 02-19-2007 02:00 PM
Boat Painting Cost 75HUSTLER Boat Design 11 10-11-2006 11:24 PM
Boat painting questions.... futuresweets-10 Fiberglass and Composite Boat Building 27 06-04-2006 08:26 PM
Re-painting old bass boat Rayb Boatbuilding 5 07-11-2005 06:50 PM
