#31
| "...I believe it will take the loads...don't you think so?..." You must calculate it, not guess it! |
#32
| Section Modulus I'm getting crazy of section modulus calculation, for T bar with scantlings 65x50x7mm I got SM=8.6cm^3, but even I did these calculations many time, still suspiciuos about this result ; could someone confirm it? Thanks |
#33
| Frame sapcing You were completely right when you asvised to change the fr spacing, check this link http://www.nomadmarinekits.com/assets/home.htm |
#34
| section modulus of just the Tee you gave gives 7.1 cm^3 |
#35
| got it, thanks Last edited by ringoo83 : 02-19-2009 at 10:17 AM. |
| aluminum boat | Robin Matulja | Boat Design | 8 | 10-15-2008 04:42 AM |
| Aluminum boat leaking | kati | Boat Design | 3 | 10-21-2007 05:45 PM |
| aluminum boat | dar | Open Discussion: All Things Boats & Boating | 7 | 05-21-2007 12:10 AM |
| Aluminum Canal Boat | hakl | Metal Boat Building | 0 | 10-31-2006 01:35 PM |
| aluminum boat help | texasboatbuild | Metal Boat Building | 12 | 09-20-2006 04:01 AM |
