| aluminum boat Hello to all, Could somebody tell me which is the approximate weight of aluminum as the construction material in the 30' motor boat? |
| I think that it really depends on the application (what will the boat be used for? what is expected of it?), but I think at a minimum you would want 0.250-inch for the bottom and 0.125-inch for the rest. It also depends on how the boat is built - if you have a lot of good structural ribs, etc., you could probably get away with a bit lighter gauge. |
| You should go for Aluminum 5083-O http://www.matweb.com/search/DataShe...70fb806&ckck=1 or Aluminum 5086-O http://www.matweb.com/search/DataShe...7e328d02419587 Density of both is about 2650 kg/m3. P.S. (sorry for you other guys...): Kontaktiraj me na private ako ti treba savjet ili pomoc. ![]() |
| depends on your speed requirements and sea state fast boat at sea, in good sized chop, I would plate in 8mm the bottom with 5 mm, full length girders, for slow boat, 6mm I would use 5 on the topsides, and 4-5 on deck and 4 on superstrucure your bottom is critical you can pm me and I will send you some drawings, I have built many al al yachts and motorboats Stu |
| Ah, maybe I have misunderstood the question... He was talking about the weight, so I gave him the weight. ![]() |
| yes I was talking about the weight (measured in kilos or pounds) thanks to all anyway! ![]() |
| Hvala ti na pomoći! |
| For 30' planning powerboat the weight of hull, deck and cabin structure designed to ISO12215-5 will be about 1800 kg. Thickness is likely to be 6 mm at bottom provided that bottom panels are about 300-350 mm wide. For rest of structure thikness is about 4 mm. These data not for construction, just for quick reference ![]() |
| thanks Alik! |
| Aluminum boat welder available $15/hr | nikos9889 | Boatbuilding | 1 | 01-02-2008 03:13 AM |
| Aluminum boat leaking | kati | Boat Design | 3 | 10-21-2007 06:45 PM |
| aluminum boat | dar | Open Discussion: All Things Boats & Boating | 7 | 05-21-2007 01:10 AM |
| aluminum boat help | texasboatbuild | Metal Boat Building | 12 | 09-20-2006 05:01 AM |
| Aluminum and wood boat | SFC Hall | Boat Design | 9 | 06-22-2006 01:18 PM |
