Old 10-07-2009, 07:00 AM
pankaj.k1980 pankaj.k1980 is offline
Rep: 10 Posts: 2
Aluminium vessel
Hii,I would like to know about the deadmass ratio,which we use in order to determine the preliminary displacement.e.g. for a passenger vessel ,
Deadmass ratio = Cd = Deadwt/(total displacement) = 0.35..
I would like to know that is it valid for only steel vessels or for aluminium vessels as well....or do we have some other empirical relations for aluminium vessel...
I would also like to know some roght estimate of aluminium that is used to make a 100 passenger vessel...
Old 10-07-2009, 08:11 AM
Rep: 1734 Posts: 8,389
Deadmass? What are you talking about? You first need a design so an estimate of materials can be done.
Old 10-08-2009, 02:57 AM
Yacht Designer/Builder
Rep: 3465 Posts: 11,677
Another example of folks in dire need of a professional . . . or more aptly, folks that think they don't . . .
Old 10-08-2009, 07:32 AM
Rep: 10 Posts: 2
deadmass ratio
Well..deadmass ratio is an empirical relation used to determine the preliminary estimation of Lightship.....furthermore,different kind of vessels have got diffrnt deadmass ratio......I think it will help you to understand my query....rgrds
Old 10-08-2009, 08:03 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 2188 Posts: 3,736
You seem to undertsand what 'deadmass' ratio is, so, all you have to do now is find out, what are its limits of the ratio you have been given or selected. That will give you your answer...
If you don't know or can't find it....i refer you to post #3.
Old 10-09-2009, 03:47 AM
Crag Cay Crag Cay is offline
Rep: 607 Posts: 644
Again an interesting question seems to have been met with the usual snotty responses from some quarters.
All the deadmass ratios I have seen quoted for various types of ship have all clearly stated 'net steel mass' in the calculation. Why is it therefore not reasonable for the OP to question if the oft quoted figure for a passenger vessel (0.35) is still valid for a vessel built in aluminium? And is this ratio still valid for passenger vessels as small as 100 pers?
Old 10-09-2009, 04:41 AM
Hey Crag Cray: Why don't you answer the question then? What is the "deadmass" of aluminum for a 100 passenger vessel?
Old 10-09-2009, 04:55 AM
Rep: 607 Posts: 644
Gonzo, as I said in my reply, all the deadmass ratios I've seen quoted to help in the preliminary design of ships, clearly states 'net steel mass' in their formulation. Is it not unreasonable to assume that this component of the DMR will vary in a vessel constructed entirely in aluminium? (presumably by the relative masses of a steel and aluminium in the structure).
But as these 'rules of thumb' are used in the very preliminary design stages, to calculate it is a very long winded if someone knows of a suitable figure that has already been published.
I don't know of one, but then large aluminium passenger vessels are not my field. But what's the harm in asking?
Old 10-09-2009, 04:59 AM
I have no problem with asking. I have a problem with calling us snooty. Why don't you give him an answer instead of stalling?
need help for livestock vessel zizoamin1 Projects & Proposals 4 03-29-2009 04:20 AM
vessel delivery fishingaz Open Discussion: All Things Boats & Boating 6 09-21-2008 01:38 PM
GA of passenger vessel pavel915 Boat Design 2 12-15-2006 11:29 PM
Specing out a new vessel Guest Fiberglass and Composite Boat Building 1 09-20-2004 06:08 PM
want a new vessel? THERIAULTMARINE Press Releases 0 08-28-2004 01:55 AM
