| Aluminium Boat With Steel Piping Dear Friends, I'm working on a project of a aluminium fishing vessel, most of the piping system are going to be built in steel so my question is: Where to find good information about types of solutions for joints between this pipes and the hull, and isolation details like for instance: - Certified discharge valves attached to hull shell and seachest valves, I was thinking on using plastic coated valves or plastic liners for the bolts together with suitable gasket but don't know the best or "typical" solution adopted. - Pipe hangers, I suppose rubber between pipe and steel hangr will be enough - I have been checking requirements from one class society (ABS) but are vague and old, maybe this way they are opening the door to different solutions... If some of you have experience with this type of projects and to like to give some advice would be appreciated. In themena time, as soon as I find more doubts will put them in this post. Best regards, |
| Why using steel piping in an aluminium environment? There are some other methods. Many shipyards use PVC or PE systems; in case you flange steel against alu use a nylon gasket in way of isolator. |
| thanks for your comments DArtois, According to what I checked in the rules, plastic pipes must be only used for class III piping and therefore are not suitable for bilge nor FIFi systems (class II) unless you want the class to specially consider that case. I think the insulation would be easy to implement once agreed with the class. Maybe nylos strip for the pipe hangers would be also OK. Every idea is welcome Best regards, |
| I was in the fire sprinkler business a few years ago. Any supplier will have diaelectric fittings and hangers. They should work. |
| Hi George, I will look for that material, if somebody can give some web page for start searching can put it here, Regards, |
| Most wholesale plumbling supply store carry those parts. |
| Aluminium vs Steel | Wynand N | Boat Design | 78 | 09-20-2007 07:34 AM |
| Aluminium or Steel | Willallison | Materials | 2 | 07-27-2005 05:08 AM |
| Pictures of steel and aluminium small crafts? | Cigra | Metal Boat Building | 7 | 03-09-2005 08:33 AM |
| Aluminium Boat | Guest | Metal Boat Building | 8 | 06-08-2004 09:05 PM |
| Applications Engineer / Plumbing &piping / Autocad | Services & Employment | 0 | 06-27-2002 03:07 PM | |
