| Aluminium Boat Interior Construction Hi all, Sorry if this is a stupid question, but I'm trying to find out how, for example, carpet or material and/or wood panelling and linings, as well as cabinets are fixed to the cabin sides, specifically in the case of aluminium boats? Are they glued-in, screwed-in, or is some other methodology used? I basically want to know the process to go from a bare alloy hull and cabin to the finished interior. Any advice would be appreciated. Dave. |
| There can be a variety of methods. It depends on the materials you are using, if they are structural members, design characteristics, etc.
__________________ Gonzo |
| Are there any good references (books, links etc) you could recommend where information about the various methods can be found? |
| There are a number of resources available such as: Boatbuilding with Aluminum by S. Pollard, Colvin's book Steel Boatbuilding is worth looking at too, even if your boat won't be steel. A common method of installing interior joinery is to weld "tabs" of either bar stock or an extrusion (angle) and just screw into the tabs. |
| Hi i believe that welding angle say 50x50x8 and self tappers (screws) to fix ply would be the simplest interior fit out |
| To make an aluminum cruising boat more habitable many are foamed inside , insulates temp & noise. Unfortunatly most spray foam is REALLY FLAMABLE so a "Cieling" (a full interior lining) is a requirement . You will need to weld the tabs on before spraying the foam. FAST FRED |
| Fixings-internal Hi i do appoligise i am thinking 10mm alloy hull so as to weld direct to hull lyle Quote:
| Aluminium Construction | Troutcatcher | Boatbuilding | 5 | 01-23-2006 02:51 PM |
| Aluminium & Composite Construction | Crowie | Boat Design | 8 | 01-26-2005 10:06 AM |
| Aluminium Boat Construction | quicksail | Materials | 3 | 09-25-2004 09:24 AM |
| Plate thicknessand other scantlings for aluminium construction | Willallison | Boat Design | 14 | 05-20-2004 08:11 AM |
| aluminium fairhull sailboat construction | Jeff Kutz | Boatbuilding | 0 | 05-10-2002 08:05 AM |
