Old 11-26-2011, 02:42 AM
Squidly-Diddly Squidly-Diddly is offline
Rep: 193 Posts: 706
"Also, it greatly reduces the torque moment produced around the vertical axis by the
THIS IS WHAT HAPPENS WHEN A BOAT YARD DESIGNS AIRCRAFT!!!
"Also, it greatly reduces the torque moment produced around the vertical axis by the propeller in the single engined configuration. At take-off in particular this motion is expected to be less than half that of the BV141. After take-off the moment is reduced to less than a third and it completely disappears at high speed cruise settings."
http://www.luft46.com/bv/bvp19401.html
Personally, I think old Dr. Richard Vogt must have just liked explaining that it really, really WOULD fly just fine, just to show off.
But I guess since boat are all very asymmetric from top to bottom, unlike a WW2 single engine fighter, the torque isn't a factor.
Now if we were taking FAST MINI-SUBS, we make use of Dr Vogt's asymmetric anti-torque principal...but I think battery ballast takes care of most of it.
The Germans did have a asymmetric recon/light bomber, 'the flying green house'. I wonder if it was an attempt to 'psych-out' opposing troops by showing something that common sense say just wouldn't fly right. http://en.wikipedia.org/wiki/Blohm_%26_Voss_BV_141
Or maybe they'd let foreigners tour the factor floor knowing the confusion the later debriefings would wreak.
http://1.bp.blogspot.com/_fhZZ63PRjh...600/adler5.jpg
" Two of the new Blohm and Voss Bv 141 aircraft, conceived to fulfill 'Sonderaufgaben' (special duties) for the Luftwaffe and which have already proved their value in numerous sorties over front-line areas.."
Blohm & Voss BV P.194
Blohm & Voss BV P.111
measuring wave height produced by boat using software sobo Software 2 11-06-2010 08:37 AM
Vertical acceleration Kastally80 Class Societies 1 08-28-2008 05:34 AM
How to calculate the pressures produced by a prop in a tube? RipSlider Propulsion 0 07-28-2008 07:05 PM
What's the "Welch Axis?" Earl Boebert Boat Design 5 05-07-2007 12:11 PM
hey i need some educating so if u can help plzz do i appreciate greatly! Islandboy Powerboats 1 09-10-2006 10:00 PM
