Old 04-23-2006, 10:51 AM
Figgy's Avatar
Figgy Figgy is offline
Rep: 88 Posts: 315
Akermann Steering
I'm basically blowing up Tornado plans to 150% for a fast 30' cat. Among other things to consider, I was thinking about the steering. A quick search brought up a spread in Professional BoatBuilder about Akermann Steering. A quick quote:
"When both rudders go over at the same angle, the outboardrudder is actually too far over and stalling somewhat (excess drag), while the inboard rudder isn't over far enough (insufficient steering response)."
Basically I'll make it so I have a 10 deg. in-angle. Is this something worth considering in my design? If I apply this for a cat, would I even notice? Do A-cats use this type of steerage now?
I could not post the picture, it's a PNG file and my version of Photoshop sucks.
Thanks for your help. Opinions always welcome!
Imagination is more important than knowledge.
-Einstein
Old 04-25-2006, 02:50 PM
BillyDoc BillyDoc is offline
Rep: 266 Posts: 421
Dual-rudder pplication of the Ackermann principle
Figgy,
I don't know how much difference it would make, but it seems to me that the linkage for an Ackermann-principle dual rudder system is simple enough that it is worth trying. I posted an image for automobile Ackermann below (from: http://en.wikipedia.org/wiki/Ackerma...ring_geometry). To apply this to a boat it seems to me you could use the center of lateral hull resistance as the equivalent of the point shown on the diagram centered on the differential and arrange the linkages to the rudders as shown.
This is just a guess on my part, however!
Bill
Old 04-25-2006, 05:37 PM
Corpus Skipper's Avatar
Corpus Skipper Corpus Skipper is offline
Hopeless Boataholic
Rep: 173 Posts: 604
There was a good article on this in the last issue of Professional Boatbuilder. Don't know how much difference it would make in a cat, they weren't mentioned in the article.
Craig Cavanaugh
Silver King Custom Marine
No shoes, no shirt, no problem!
Old 04-25-2006, 10:27 PM
Figgy's Avatar
Rep: 88 Posts: 315
Corpus Skiper- Pro Boatbuilder is where I got the idea from. I never really gave the steering too much thought untill I saw it. The idea came when they mentioned twin-screws boats on pg.104. I just thought it might be applied in my case.
BillyDoc- Thats a good idea! I wasnt really sure it was an idea worth consideration. The more I thought about it, the more it made sense. I'm curious if its worth the time and effort....it doesnt matter, I'm going to do it anyway
Thanks!!
-Einstein
Old 04-26-2006, 07:11 AM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Figgy,
WE used to use this on BOC-style boats with twin rudders. In the "dead ahead" position, aim the tiller arms at the boat's pivot point (guess at it, it'll be close to the keel root). That usually does it.
Also, be aware of the flow from the transom. Do not just aim both rudders dead ahead and forget it - check where they have least drag (hint - it will probably mean you have to toe them OUT)
Steve
Old 04-26-2006, 08:37 AM
Figgy's Avatar
Rep: 88 Posts: 315
In the dead ahead position on a 30' cat, why wouldnt that induce drag? I see how that would work for turning, but it seems to come at a price. How well did it work for you? Did you notice a difference in performance?
-Einstein
Old 04-26-2006, 10:11 AM
SailDesign's Avatar
If you're talking about a cat, then you are not going to have to worry about toe-in - I was talking monohulls
Steve
Old 04-26-2006, 10:13 AM
SailDesign's Avatar
Figgy - the tiller ARMS should be aimed at the pivot point, when the RUDDERS themselves are aimed dead ahead.
Steve
Off Throttle Steering pberardi Boat Design 5 04-21-2006 01:20 PM
Steering Wheel garys Boat Design 9 12-20-2005 02:34 PM
Steering systems diazklm Powerboats 2 11-11-2005 04:03 AM
Self Steering Gear panthablue Sailboats 18 07-09-2005 07:59 AM
Steering Question Travis Powerboats 3 08-13-2004 06:46 AM
