Originally Posted by fng samnz just ring your supplier and see if you can buy half a mtr or so, then bring it round and we'll have a play. Most of the time you would be required to heat the C70 to develop the type of curves you play with, so lets see what we can do with a side buy side test. In consideration of the fact that the foam is designed to be used in impact areas you may well get away with using less laminate. For example typically in your style of yacht 400-450g/mtr laminates is concidered strong enough, but not strong enough to stop brusing in the event of nudging a dock, or a raft up ... So typically it is recomended to go for 600g/mts outer skins.
I have several test panels you could compare too with C70 and varous liminates |
thanks, I would like to do this, I have allready purchased the foam, but would like to do some tests to see if i can get away with 300 DB glass on each side for the floats decks, its only a small area and not likely to be walked on much, my current boat has 4mm ply with one stringer and hasnt broken, the foam and glass must be much stronger.
