Old 10-07-2010, 10:22 PM
Mat-C Mat-C is offline
Rep: 109 Posts: 242
African Cat - Another Hybrid....
Came across this cat being built by African Cats..
Quite a lot of unusual features - for me at least. The most obvious being the apparent use of the Axe-Bow hull shape....
Then there's the laminates...
She is being built in epoxy thru resin infusion with basalt fiber for hull and deck, carbon fiber optional (displacement minus 700 kilo / 1540 lbs), saloon roof and bimini in carbon fiber, Twaron/Kevlar impact protection in the hulls.
Basalt is a rock where I come from....
And then, of course, the must have hybrid propulsion system...
Hybrid ECO POWERCAT GREEN MOTION version is powered by 2 x 18 KW electric motors and a 23 kW high efficient diesel generator
Is my maths off, or can you really run 2 x 18kW motors with one 23 kW generator?
Old 10-08-2010, 09:58 AM
steff steff is offline
Rep: 40 Posts: 7
Basalt fibres
Hi Mat-C,
they are more knowledgeable design people on the forum to answer you question on the hull shape, then me, just wanted to say the designer Lavranos is not a newcomer and so there might be some good reasons behind it.
On the basalt fibres - you are right is a stone, if I recall correctly the Russians ran a development program for it, but it never took off commercially, however it is a real substitute to E-Glass - here a quote:
Basalt roving 2400 tex
As a basic material, basalt is a black, alkaline extrusive rock.
Properties:
With only 5 % higher density than the conventional E glass fibre, basalt fibre offers in comparison with it a 15 % higher tensile strength, higher compressive strength and rigidity (modulus of elasticity). The thermal stability is extremely high, the fibres themselves only begin to melt at 1450 °C. The chemical endurance, especially against strong acids, lyes and solvents, is very good.
Application:
Applications, which, with regard to rigidity and strength, fall between E glass and HT carbon fibre, e.g. spars, force transfer points, wound components, profiles etc. in automotive engineering, the construction of sports equipment, model making, aviation industry and production of receptacles. Suitable for epoxy, vinyl ester and polyester resins.
Technical data:
Basalt fibre
Density: 2.75 g/cm³
Tensile strength: 4840 MPa
Compressive strength: 3792 MPa
Modulus of elasticity: 89000 MPa
Elongation at break: 3.15 %
E-glass fibre
Density: 2.6 g/cm³
Tensile strength: 3450 MPa
Compressive strength: 3033 MPa
Modulus of elasticity: 77000 MPa
Elongation at break: 4.7o %
Now to your question on hybrid propulsion - no your maths is right - this set up works only for recharge or medium usage of the e-motors, however there will be a battery buffer bank in between, to cover the peaks. It may very well be that the cat performs well under motors with only half the rated kw is used and it also depends which system, in terms of voltage is used, to achieve a high overall efficiency.
Hope this clarified your findings a little...
Regards, Steff
Old 10-08-2010, 10:10 AM
apex1
One at a time, of course (or better: off course as the whole hype).
Basalt fibre is common stock since ages.
Regards
Richard
Old 10-08-2010, 01:43 PM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1348 Posts: 2,051
Some info from another source
Tensile Strength E- Modulus
Basalt 2418 MPA 85 GPA
E-glass 1800 MPA 72 GPA
S-glass 2556 MPA 89 GPA
Mobile Water based clinic. Solution for health care on African waterways. PMDT83 Boat Design 17 07-21-2010 08:44 AM
Rig handling: Cat Ketch, Cat Schooner, Sloop, Cutter Seafarer24 Sailboats 8 05-30-2006 10:06 AM
South African seeking advise Zeanne Education 2 07-26-2005 04:39 AM
South African seeking advise Zeanne Boat Design 4 07-01-2005 01:11 PM
African Queen Plans rob98801 Boat Design 7 01-22-2005 10:30 PM
