#121
You are basically trying to make a 50' Home Depot war canoe with a stick and a sail. Next you say. Quote:
#122
| This is a Ray Hunt 510 , 38' x 6'-6 ', draft of 5'6" slab sided flat bottom I dont know what the rest of the specs. are . You should talk to a naval architect . ![]() |
#123
| Frank, Thats a very interesting boat. Do you have more info on it? Ray Hunt designed many 6-1 boats with flat bottoms and slab sides. The boats are known for being fast and good handling. For thier time, it was unusual to have the deep draft fin keels he used. Still need to figure out how jubilee can sail without deep draft and off course smaller sails are required, so less speed. |
#124
| Frank Smith you picture and discription does not say one damned thing about that boat. Nor does it address the problems with Goodwilltoall's design. Seriously. |
#125
#126
sailing boat. So i think you will agree that it has been done . It is also not my intention to design Goodwilltoall's boat. Perhaps you can fill in the blanks for him. |
#127
I do not see what I was refering to as slab sided on that Hunt sailboat. Secondly, how do we know what the underwater lines are as you have not posted a midsection plan. In fact you admit to knowing very little about this boat. The two boat are likely not even close and not even close on intended purpose. Apparently you meant for you post to simply point out that there are narrow beam relatively flat bottom sailboat designs out there which is fine but your post leads to this. Quote:
To me Goodwilltoall would be far better off taking the $12k and enrolling in Westlawn or McNaugton. In the long run he would save much time, headache and money. One thing is for certain, If Goodwilltoall proceeds as he has planned he will pay for his education one way or another but, the informal way is more expensive and time consuming in the long run. Been there and done that, never again. |
#128
| Why do you think it will snap roll something terrible? Any boat will roll , I dont see this shape as that much different . |
#129
Part of the problem is that Goodwilltoall has not really laid out why he wants to build this boat and what he expects it to do. We don't know if he has a devine calling or a desire to build a really cheap boat cuz he has no money or if he is a tree hugger hell bent on saving the planet with some sort of mission statement in a boat. The direction he is going is not the direction I would take where I to want to travel in a boat. With $12,000 as a budget I would eliminate the desire to cross an ocean. Cha Ching, we can save a bundle. I would eliminate two forms of propulsion as in, kiss the sailing rig good bye. Cha Ching, more money saved. I suppose if I wanted to stick to what he seems to want in a boat I would get with Mystic Seaport Museum and get a set of plans for Bill Garden's Tlingit and have at it with the Home Depot lumber and epoxy. I would look around for something like a Sabb 2H with controllable pitch propeller on the cheap. For $12k and a years work I would be out havin fun. Cruise speed would be 10 knots on a little under a gallon per hour. You could go to Florida and Back to Cleveland on 300 gallons of fuel. That is like a crusing budget for fuel of less than a grand a year. |
#130
| I have a link to a discussion on Tlingit here on the forums last fall. Missing Bill Garden designed launch - Anybody seen it? |
#131
| Pierre, Did some checking around, the 510 is slab sided and flat bottom, it is one in a series (110,210,310,410, &510) with all of them beign 6-1 ratios. Also know about Tlinglet, that one is just a engine boat-no sails. The 110 & 210 were excellent sailing boats, for jubilee the draft is to be thin water use, therefore need to figure proper sails and ballast. Further the boat could be used as strictly with an engine until sails are put on. The problem with this would be that the "V" shape wouldnt be working to provide a smoother ride and some sails if just only riding sails would be beneficial to provide a more stable ride with less rolling and also a get home measure if the engine fails. Peace. |
#132
as Pierre already mentioned, you would be better away to tell the audience what your real intention is, instead of dreaming on about the "Oviparouswoolmilkpig". A proper SOR would be nice to start your planning. The so named "design spiral" will then soon tell you what is within your plans and possibilities and what not. The Design Spiral, or where to start building a boat. Spreading your (usually wrong) opinions about different designs around on the board does neither help you, nor does it entertain the members. Regards Richard |
#133
| I am regreting using the word "slab sided" as a chide Goodwilltoall as you did not understand it. I kinda meant totally vertical hull sides from sheer to chine as in your drawing. |
#134
#135
| Pierre, The Ray Hunt sailboats are totally vertical sided and flat bottomed, the only difference is that at the chine there is about a 3" radius, and maybe the hull height is more than 60% of hull beam, not sure. Guess that cross section drawing shown in post #1 would be a close approximation to midbody section. Apex, Tell us what the wrong opinions are so they can be corrected. There are many descriptions describing what the boat would be used for in previous posts, what else do you want to know about the intended purposes? What is the meaning of "oviparouswoolpig"? Also dont know what the acronym SOR stands for. The "V" would be the shape the hull would see at the water when sailing heeled, though as Bolger said the efficient heel for this type of hull is 10-15% which wouldnt be much but it would help some. |
| An ideal small affordable motorsailer | Greenseas2 | Motorsailers | 12 | 08-28-2009 09:32 AM |
| 5 Axis - affordable | Kobus Potgieter | Projects & Proposals | 1 | 01-10-2008 09:11 AM |
| Need Affordable 3D Renderings | Arthur W. Kelly | Services & Employment | 3 | 04-14-2006 02:01 PM |
| Affordable, long-term liveaboard? | Filmdaddy | Projects & Proposals | 22 | 12-22-2005 10:25 AM |
| Affordable good rendering software | Johan | Software | 3 | 03-12-2005 09:28 PM |
