Note: This feature may not be available in some browsers.
Would have to guess that ark in cross section was rounded at chines, had flared sides (but almost plumb), and the bottom had just slight arc. This is just a guess but if you take any shape and use those lines to design a boat with the ark ratios being used for overall beam, hull depth, and length, the boat becomes superior compared to most fat beam, short, high freeboard boats.
As mentioned before the dutch barges with thier bluff bows are not acceptable for ocean work whereas the Thames barges were found to make excellant ocean boats
Yep, I noticed it, that's why I'm here - to research and discuss boat designs. I'm just trying to shed a little light on where I think this guy is coming from. Most rational people have a hard time getting it.
This is not really adequate to drive the boat if the boat is heavy enough for its waterplane. That said the beam and ballast ratio may not match either.Greetings,
Have heard no thoughts on the 600sf sailplan.
The ballast ratio is not determined by a number but by what is necessary for stability. Stability is determined by the lines and weight distribution.So is 35% inside ballast ratio with above sailplan doable?
This is not a sure fire way of designing a boat to say the least.Without knowing the science of exact engineering for allowable stesses on certain materials (sail cloth, masts, hulls, ballast, heeling, and hundreds more formulas and calculations); observation of other successful and similar designs and why they work well becomes the means of learning how to apply those principles into a design that you also would want to work well in the same conditions.
As example: using the as39 again for overall shape, draft, sail area, mast height, and ballast; we can conclude that using similar design characteristics certain behaviors will result if we stay near those parameters.
I am afraid that the biblical ark is not in that category.All new technologies, techniques, or designs in the end are deemed acceptable by being able to observe them performing as intended.
You really have not asked question with enough information to determine an answer. When general answers are given you write them off as not meeting your criterion. You are difficult to help as you are not really designing a boat in time tested sensible ways that have worked for at least the last 200 years.Calculations and formulas help, but they are not always necessary. So if some of you through engineering can say above ratios will or will not work, and if some people through experience and first hand knowledge can also make a determination, those thoughts and ideas will be appreciated to answer questions I have.
