  #46
Old 08-04-2010, 07:22 AM
frank smith frank smith is offline
Rep: 185 Posts: 980
Why is it some people find it necessary to force their religious BS on others ?
No need to answer , just dont do it .
Boat design is science , not pie in the sky. This is the reason I like it .
Either it works or it dont.
  #47
Old 08-04-2010, 07:30 AM
SamSam's Avatar
SamSam SamSam is offline
Rep: 971 Posts: 3,428
Originally Posted by goodwilltoall View Post
Following above proportions, proposed cruiser dimensions above would be: length 50'-0" x 8'-4" beam x hull depth 5'-0".
Getting back to proportions, I would like some of you to consider a measurement to test the quality of the hull to make it seaworthy, efficient, and seakindly. Lets take the 50 footer and take away all appendages (fins, rudders, masts, keels, ballast, etc.), next take the three dimensional numbers every hull has(lenghth, height, width) and multiply which gives the number 2083 cubit foot for the 50 footer.
Use that number and take any other hull and proportion it to equal it 2083.
Now this I hope can be a starting point where certain qualities can be compared to each other.
Why work with erroneous numbers? That is not even close to the cubic feet of your boat in the drawing.
  #48
Old 08-04-2010, 04:08 PM
MatthewDS MatthewDS is offline
Rep: 48 Posts: 104
Quote: "Use that number and take any other hull and proportion it to equal it 2083.....So think of any boat you can and see if it can stand in a head to head comparison with the Ark."
What on earth are you talking about? Are you honestly suggesting boat design by numerology?
I don't see any point at all to what you are doing. If you really want to recreate the ark, why not build a vessel based on a design from the time period? I'm assuming you think that the flood happened somewhere around 5000 BCE, so open a history book, find out what they were building then, and try to replicate it. The most likely construction methods are bundled reeds or lapped cedar or similar.
I also think that everybody has gotten so worked up about the superstitious nonsense behind his idea that they lost sight of the actual problem here.
You can't scale dimensions from one design to another and get good results. It doesn't work that way. All the magical thinking in the world won't change the fact that even if you had a complete set of plans of the Ark, you couldn't scale them down to 50 feet, and have a boat even remotely close to the original.
Last edited by MatthewDS : 08-04-2010 at 04:11 PM. Reason: Oops.. Not cyprus wood. Probably cedar.
  #49
Old 08-04-2010, 04:35 PM
Rep: 185 Posts: 980
Here ya go , It could be built with lumberyard material
  #50
Old 08-04-2010, 04:48 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Wood Butcher
Rep: 2489 Posts: 5,313
The wood is cypress and it grows in the Middle East today. Ask the Israelis and Lebanese who just fought a battle over a cypress tree.
Fracking is good.
  #51
Old 08-04-2010, 04:49 PM
hoytedow's Avatar
Wood Butcher
Cyprus is an island.
Fracking is good.
  #52
Old 08-04-2010, 04:55 PM
Rep: 48 Posts: 104
Ah, thanks. Cypress was my first instinct (hence the edit) However, I remembered that Cheops Funeral Boat was made of Lebanese Cedar, and that Cedar had been used in Egypt at least to 4000 BCE, so I went with that.
  #53
Old 08-04-2010, 04:57 PM
hoytedow's Avatar
Wood Butcher
Do you mean 4000 Before Christ? He really is a historical figure even if you don't follow him. We won't let you scrub him from this thread. BCE is a new term invented by secularists to erase Christ from history. We will not yield while we yet breathe.
Fracking is good.
  #54
Old 08-04-2010, 05:03 PM
Rep: 185 Posts: 980
then troll on
  #55
Old 08-04-2010, 05:07 PM
hoytedow's Avatar
Wood Butcher
That is how you fish.
Fracking is good.
  #56
Old 08-04-2010, 05:14 PM
Rep: 48 Posts: 104
Not to get completely sidetracked, but the term "Common Era" was first used in 1615 by Johannes Kepler. Anyway, back to building the Ark!
  #57
Old 08-04-2010, 05:17 PM
wardd wardd is offline
Rep: 442 Posts: 899
If I lash together a bunch of logs for an affordable seaworthy cruiser, should I remove the bark?
  #58
Old 08-04-2010, 05:21 PM
hoytedow's Avatar
Wood Butcher
Yes, Kepler had a hard llife and his faith was severely tested. Even so all he did was remove Christ from the decriptor but retained the numerical quality based upon Christian timekeeping. What does that prove? Zilch.
Fracking is good.
  #59
Old 08-04-2010, 05:30 PM
Rep: 442 Posts: 899
Seems christians had little or nothing to do with the calendar until pope Greggory.
The Julian calendar, a reform of the Roman calendar, was introduced by Julius Caesar in 46 BC, and came into force in 45 BC (709 ab urbe condita). It was chosen after consultation with the astronomer Sosigenes of Alexandria and was probably designed to approximate the tropical year, known at least since Hipparchus. It has a regular year of 365 days divided into 12 months, and a leap day is added to February every four years. Hence the Julian year is on average 365.25 days long.
The Julian calendar remained in use into the 20th century in some countries as a civil calendar, but has been replaced by the Gregorian calendar in nearly all countries.[1] The Roman Catholic Church and Protestant churches have replaced the Julian calendar with the Gregorian calendar, but the Orthodox Church (with the exception of Estonia and Finland) still use the Julian calendar for calculating the dates of moveable feasts. Some Orthodox churches have adopted the Revised Julian calendar for the observance of fixed feasts, while other Orthodox churches retain the Julian calendar for all purposes.[2] The Julian calendar is still used by the Berber people of North Africa, and on Mount Athos.
The notation "Old Style" (OS) is sometimes used to indicate a date in the Julian calendar, as opposed to "New Style" (NS), which either represents the Julian date with the start of the year as 1 January or a full mapping onto the Gregorian calendar. This notation is used in reference to dates from tsarist Russia (the country did not switch to the new calendar until 1918).
  #60
Old 08-04-2010, 05:32 PM
hoytedow's Avatar
Wood Butcher
Still, the dates are the same.
Fracking is good.
Affordable, long-term liveaboard? Filmdaddy Projects & Proposals 219 02-28-2015
05:39 PM
An ideal small affordable motorsailer Greenseas2 Motorsailers 12 08-28-2009
09:32 AM
5 Axis - affordable Kobus Potgieter Projects & Proposals 1 01-10-2008
09:11 AM
Need Affordable 3D Renderings Arthur W. Kelly Services & Employment 3 04-14-2006
02:01 PM
Affordable good rendering software Johan Software 3 03-12-2005
09:28 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
