#136
#137
| Another description of boat use would be to limit stops at marina's. If proper provisioning is made for long journeys the more secluded areas would become favourable destinations. With collecting water on the hull, selfcomposting head with urine and hard waste seperated, and occasionally fishing this can become a reality for upto several months of cruising. With the shallow draft capabilities, natives to areas like the Bahamas would be encountered more often and regular one on one trading patterns could be developed with them. Would like to add more space and displacement but the design is filled up with most of the necessary requirements. Once the sail and ballast system is settled a simple build can commence that perhaps a couple with small children can easily afford and if smartly handled (with off course good seamanship skills) should be able to provide the qualities as mentioned at beginning of thread -Safe, affordable, and seaworthy. Once boat is built incremental testing of designed qualities can be proven, with looking at predecesor boats of similiar design, good results can be expected. This in not all that new and can be done. |
#138
following the advice is always a better choice than drivelling on! So read what our patient and knowledgable members told you, and follow the links, it is easy to grasp, even for a completely biased novice like you! Quote:
The former post shows again, you are still just dreaming and have near to zero experience at sea, less on boat building and even far less on boat design. So why donīt you go to the thread I linked to? And "Oviparouswoolmilkpig" is a self explaining term! Richard |
#139
| Have at it Goodwill, its your money. |
#140
| Pierre, Understand that increasing static stability does not enhance ride, never rejected that. That is why long length is needed so that static stability can be reduced, and have to go back again to mentioning that long length is not considered often with modern boat design. When the modern 35' fat hulled design is compared at bottom waterplane, more pounding will be likely to result. They are not completely flat but deadrise is not that great either as some of the broad sterned euroboats show. With modern BWL say 10'-8" compared to jubilee 8'-4" BWL that has to account for more uncomfortable ride especially when overall length of 50'-0" compared to 35'-0" is considered. Hate to keep beating this around, but long length and narrow beam is proven to offer a better ride. |
#141
#142
| Why not build the AS39? |
#143
#144
| Apex, You came back again not to offer anything useful, only to detract. Dont mind having you onboard, it would be good to stay on topic in regards to the design at hand and make some helpful suggestions to work out a better design. If not its better to just excuse yourself from this discussion. Peace to all. |
#145
#146
#147
#148
| I dont get the draft . In you opening post you say 5' max . Then you say hull draft of 1'4' and then 19". You need to get a better idea of what you want, i think. |
#149
#150
| An ideal small affordable motorsailer | Greenseas2 | Motorsailers | 12 | 08-28-2009 09:32 AM |
| 5 Axis - affordable | Kobus Potgieter | Projects & Proposals | 1 | 01-10-2008 09:11 AM |
| Need Affordable 3D Renderings | Arthur W. Kelly | Services & Employment | 3 | 04-14-2006 02:01 PM |
| Affordable, long-term liveaboard? | Filmdaddy | Projects & Proposals | 22 | 12-22-2005 10:25 AM |
| Affordable good rendering software | Johan | Software | 3 | 03-12-2005 09:28 PM |
