Old 10-03-2004, 05:26 PM
Ian W Ian W is offline
Rep: 10 Posts: 3
Aero foil rudder speed limitation
Hello,
My recently acquired planning TSMY is fitted as original with GRP aero foil section rudders.
All but my vessel were fitted with twin 210 hp diesels to exposed shafts supported by
'P' brackets.
However, my boat was custom built in 1976 and fitted with 300 hp diesels and using the same rudder pattern as the 210's.
The maximum respective speeds are approximately 21 and 28 knts.
Before I become too paranoid about the strange steering characteristic I am experiencing, would anyone be able to throw light on possible causes?
To this end are there limitations with any state of the boats trim or speed when using this design of rudder as opposed to a more flat section bronze rudder used on similar boats?
Thank you in anticipation.
Ian.
Old 10-03-2004, 08:13 PM
JCFARER JCFARER is offline
Registered
Rep: 10 Posts: 54
Originally Posted by Ian W
Hello,
'P' brackets.
Ian.
Hello Ian,
Wow, you increased the HP by 1.43 times and your speed increased by 1.33 times. What are the strange steering characteristics?
Was the motor support structure beefed up further? Are the shafts bending or bent from the extra horses? What about attachment points for the rudders...are they structurally sufficient? Is the prop the same? Does the rudder have sufficient inner plate area to keep it from deflecting under the extra rpm's? Do you get linear or tangenial deflection at the rudders? Is the shaft angle to the motors correct? Hmmm, I would probably ask those questions first to begin the process of elimination.
Good luck...
Jay
Old 10-04-2004, 05:07 AM
Rep: 10 Posts: 3
Hello Jay,
I'm sorry, my question was not clear. My concern is merely rudder design application and what goes on below the waterline at planing speeds. Regardless of whether the boats were manufactured with 210`s or 300`s, for 30 years owners have lived with the same short coming. At planing speed a slight hint of helm and the rudders will continue turning, and obviously very resistant to recover the ahead position. I do wonder if the naval architect made a conscious design decision to provide reasonable displacment speed steerage and only relatively straight line planing speed use. Unfortunately most of the boats passages are at 23 knts and when I think of the drag this design also presents I am open to suggestions either way. Or perhaps I should accept compromise more readily.
Thanks Jay I appreciated your rapid response.
Ian.
Old 10-04-2004, 06:11 AM
Rep: 700 Posts: 3,208
Wonky steering at high speed can be caused by cavitation down the rudder surface.
The simpletst cure is a fence at the top of the rudder that stops the air entrainment.
FAST FRED
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
rudder foil selection Hravn Boat Design 18 02-17-2011 11:30 PM
Newport 27 Rudder?? MrJunk66 Sailboats 33 08-03-2009 08:09 PM
Pros and Cons of Transom Hung Rudders Gone Ballistic Sailboats 19 09-19-2005 09:15 PM
Aero foil rudder speed limitation Ian W Boat Design 0 10-03-2004 05:32 PM
