Old 02-18-2005, 09:43 PM
KSC KSC is offline
Advice Needed
Welcome comments on converting a 23' SeaCraft inboard power boat hull to outboard power. (See attachments). Can the outboard motor run in thr rather large pocket left by the inboard design? If so, should the engine be mounted close to the cut-out or out on a bracket? The desired purpose is to acheive a craft that can handle the open waters of the Chesapeake Bay. but capable of idling into shallow tidal coves and creeks. I would like to be able to trim up the engine an let her rest on the bottom occasionally. I am sure there would be some trade offs, but is it possible? Thanks, <KSC>
Advice Needed-seacraft-hull.jpg  Advice Needed-mvc-007f.jpg  Advice Needed-mvc-012f.jpg
Old 02-20-2005, 10:44 PM
Rep: 1397 Posts: 7,215
Taking out the inboard and installing the outboard will change the center of gravity aft by a lot. The boat will probably porpoise. With the prop in a tunnel, how much can you gain with an outboard?
caulking advice jools Materials 6 10-26-2006 06:47 AM
advice needed, selling woodworks for superyachts A-Form Wooden Boat Building and Restoration 2 12-24-2004 09:04 AM
Advice needed! biggathanjesus Materials 6 05-28-2004 11:44 AM
Force needed to roll or counter roll fer_mayrl Boat Design 1 02-13-2004 04:21 PM
Advice Wanted Re Production Boatbuilding VIKING Boatbuilding 0 06-23-2003 05:06 AM
