Old 03-26-2004, 10:43 PM
Gypsy72 Gypsy72 is offline
Rep: 10 Posts: 9
advice on my plan please
my goal is to build and run a day charter vessel
I've checked out the long list of "cons" that go with converting a rec vessel to commercial vessel.
I've attempted to locate the right commercial vessel for purchase but have not been able to locate one yet.
I'm thinking about locating and purchasing prints to a vessel with the lines I'm looking for. Then going to a Naval Architect (with a P.E. stamp) to make the necessary changes to make the vessel meet USCG "T" boat standards. And create the cosmetic look I want to achieve.
Get the plans approved through the USCG planning board,
Get an estimate from a shipyard,
Then bring the approved design and the construction estimate included with my buisness plan to my potential backers.
Does this sound like cost effective course or not?
GS
Old 03-29-2004, 06:53 AM
CDBarry CDBarry is offline
Rep: 279 Posts: 524
No, there are significant subtle differences between charter / day boats and yachts that yacht designers just don't understand. You may be able to get a yacht design that will pass, Coast Guard, but it will be a poor compromise and cost much more than it needs to. Get a boat designed from scratch for what you want it to do. What advantage do you see in buying plans for a yacht in the first place?
It is silly enough to change an existing rec boat to a commercial boat. There at least you have some justification for doing it, here you are buying the wrong plans and spending money to half redo them to be the minimum acceptable match, than spending more money to have a custom built thing that is neither nor. I've seen this frequently - someone goes to a yacht designer and gets a poor commercial boat that costs twice what it should and does half what it could. Note also that many small shipyards will "no bid" this type of design, and it will end up costing you more that way too.
You may want to talk directly to shipyards first. Many yards doing small commercial craft have their own designs, which they are already tooled up for.
Old 03-29-2004, 09:06 PM
Rep: 10 Posts: 9
excellent advice, I've been digging since I posted this and totally agree with you.
The search for the right yard is on!
thanks for your help
GS
Old 03-29-2004, 10:18 PM
captword captword is offline
Rep: 10 Posts: 79
Have you looked into boats and harbours?yet? They have all kinds of vessels for sell in there comercial and private. they also have comercailboats in there ,where you but the already setup business when you buy the boat. What kind of business are you going to set up? You got your captains license? gonna hire a cap? I run a charter business as well as do boatwork. I maybe able to help you through the pitfalls and myths.
Howard
Old 03-30-2004, 08:20 PM
Rep: 10 Posts: 9
I've tried to look up "Boats and Harbours" but have yet to find anything. Is there a website?
Yes, I am starting a day charter buisness.
Yes, I will captain myself, for now.
I'm in the process of getting my "days" calculated from my military time.
I am going to get my 100 ton right off the bat as I already have the required days and tonage under my belt.
For obvious reasons, I cant get too deep into my intentions, but I can tell you that the target run date is Oct. 2005.
Any info will be appreciated.
GS
Old 03-31-2004, 01:46 AM
Rep: 10 Posts: 79
no they do not have a website as of yett. would bew awesome if they did. I found my firdt issue at the newstand. A good magazine or newspaper store might have it. My scanner wont scan text at the moment for some reason, but here is the info.
first class mail 36 issues 3 per month $62.00
boats and harbors
PO Box 647
crossville, Tn 38557
ph(931)484-6100
Might be well worth looking into
might save you aload of money and you might find an already set up business
Old 03-31-2004, 08:03 AM
Rep: 279 Posts: 524
Make sure you join the Passenger Vessel Association.
Composite ocean row boat advice OceanRowSolo Fiberglass and Composite Boat Building 7 01-26-2005 09:53 AM
boatbuilding advice wanted Guest Boatbuilding 7 09-12-2004 04:04 AM
Lines plan from Rhino AndyRed3D Software 14 08-04-2004 12:05 PM
Plan to fit sail kit - Any reccomendations? DrewBird Wooden Boat Building and Restoration 4 06-05-2004 07:12 PM
Advice Wanted Re Production Boatbuilding VIKING Boatbuilding 0 06-23-2003 05:06 AM
