Old 12-07-2010, 05:01 AM
Patrick45 Patrick45 is offline
Advice anyone...19' mako restoration hull-deck separation
Good mornin' 5am and wondering where to begin.
So I've been waiting for my first boat for about 37 yrs.
True. Long story of why it took so long to finally even get to this beat on mako.
I'm digging in and want to learn and rebuild her right. 1st issue I'd like to address would be the split between the hull and front deck.. I'll add more photo's later today.. It's about 1/2" at widest gap behind the bumper, but tapers down quickly. It doesn't look like water got in. The hull and floor and transom feel like rock. For a 73 mako I here that's pretty good to start with?
I've been reading about, flipping the lid, or balloons, or bolts and epoxy resin, or a newer bonding agent.
from this small split in the bow, do you think in need to take the whole deck off? What would you guys use the seal this seam up right?
I'll get to the motor later. If anyone's near mystic ct, I'm willing to trade artwork for help, or something. Any boater/fisherman would dig the art.
I'll try to clear the message up more later, just woke up.
Thanks for ANY advice on my split seam mako. I'll take close ups at lunch I hope I don't need to rip her top off... I'd like completely rebuild her in the future when my $ is better. Now I'll work with about 2g and as many hours I need. Thank You!
Sempr Fi,
Patrick
Winter project, what do we do with a drunken sailor...Shave his belly w a rusty razor, that's what we do w a drunker sailor...Put in bed w the captains daugther...early in the mornin'
Old 12-07-2010, 07:41 AM
PAR PAR is online now
Rep: 3125 Posts: 9,397
It's possible your deck cap hasn't separated from the hull, but the picture, which doesn't have enough detail, does suggest it taken a shot on the bow and popped the hull/deck cap seam. The easiest way to check this is to remove the rubber or PVC bumper in the middle of the aluminum rub rail and back out a few dozen screws, checking their condition as you go. If you discover a bunch of bent and/or broken fasteners, then it's likely there's been a really good bow impact and the hull to deck joint may be suspect.
The first thing you should do is call a boat carpenter and have him look it over. I've heard it a thousand times, "the hull is solid", when in fact after a pro looks her over, it's got a host of issues that the novice just doesn't catch. It's the same reason hookers stay in business, some things a pro just can do a lot better then the average person . . .
Fibregalss Upper and Lower Hull Separation EricM Fiberglass and Composite Boat Building 5 11-24-2009 07:53 AM
Advice on hull restoration Toddlesocks Wooden Boat Building and Restoration 12 08-30-2009 11:09 AM
Optimum Cat Hull Separation? alidesigner Multihulls 7 05-24-2009 09:44 AM
Restoration Advice cb111 Fiberglass and Composite Boat Building 3 08-09-2006 08:54 PM
Want to replace old Mako 19 deck with a "Flats boat deck" - am I crazy or what ! dan Boatbuilding 4 09-24-2002 03:48 PM
